Ive never ever had a problem jacking up a vehicle from the diff, theres nothing wrong with it. Some vehicles dont have a jacking point, so your only choice is to use the diff.
Sills are where you put the stands, because thats what they were made for, when you see a car being put on a 2 poster hoist, unless its a 4wd/ute and some vans, the 4 pads usually go under the sills.
I think aslong as you have safely rested the car on the stands, whether it be 2 or 4, and always do the shake test, i mean id rather see my car fall with me shaking it then fall with me under it. Ive never ever seen stands failim not saying they dont though.... and ive been using them regularly for a while. I guess it also depends on quality, its no use in being a cheap skate and getting some el cheapo deal, always go for what tradies use.
And i figure if you are too scared to get under a car, then just dont you start getting paranoid at the slightest creak or groan, i used to be terrified, thinking how the hell is that little puny jack going to hold up 2 tonnes of car.... but i got over it, you jsut have to place trust in the equipment you are using, and if not, just get someone else to work on your car.
but thats just my 2cents
If i need to work under a car i will always use 2 drive on ramps at the front and 2 stands at the rear.
However, if i need to work on the front that requires the tyres coming off, then i will use 2 stands on the front only, and not jack up the rear. Once finished on the front then i will use ramps to get under the car.
That'd be my preference too but my wheels are 9.5" wide! You have to buy 4x4 size ramps and they cost uber $$$. :) So jack stands it is for me then!
During my restoration i have had my car on 4 stands the whole time. Thats about 1 year on them so far. Its the proper way to lift the car when you have no hoist and a regular practise in the workshop where a hoist is not available. If setup correctly it is completely safe!
Deren
    • Just a follow-up on this topic. From what I can tell so far the rusty residue on the engine block might be unrelated to a coolant leak or maybe just older than anticipated. After driving it from the winter garage to my friend's garage I could not see any new traces of coolant leaking there, but I will test this properly once I was able to fully warm up the car and drive it for a bit. I think I can agree that the whole porous engine block stuff is kind of nonsense, but there is just a silly amount of true, false and half-true information on anything Skyline-related on the internet.
    • hrmmm , not mine , easter plans to pull engine not happening
    • I removed the IACV, cleaned it and reinstalled.  I found a video on youtube that helped with the whole process, the guy then said the idle needed to be set, so the process was to get the vehicle up to operating temperature, unplug the TPS, set the idle screw in the IACV so the RPMs were around 600, then plug the TPS back in.  After I reinstalled the IACV, the car started (because, it was a cold start), once it warmed up, the car died, I adjusted the idle screw to see if that helped anything, it did not, I had to wait about 3-5 minutes, then the car would start back up. Only to shortly cut out, and only crank.  I loosened the TPS to see if adjusting that would do anything, and when I would rotate the sensor clockwise, there was a humming noise, but it would go away when I got the sensor in the horizontal position.  It only made the hum noise with the key on.  What do you guys think? 20250414_172604.mp4
    • Quick update.  The engine grounding strap was replaced, the engine is now happily running.  Tested the voltage drop before replacing the strap, was about 1.2ish volts down between engine to battery, chassis to battery. With the new grounding strap, pretty much no voltage drop at all.
