Hi All,
Just aquired a cushion button clutch for my GTS-T, before I go ahead with the fitment I wish to find out more info about what short shifter is best recommended and most commonly trusted by fellow club members. Where can I obtain one?
Ebay has them going for $60-$120AUD for Billet Aluminium ones.
Thanks Guys & Gals.
Edited by MissRB25DET
Hey tash.. I don't know if button clutch would be your best choice, a sprung center gives a lil more flex slightly easier to drive and not as aggressive..
With short shifter i think thats a personal choice i got a NISMO(i think) one off ash and i think its ace although i don't think he liked it.
Thanx for the advice guys.
You wouldn't by any chance know the tension (Nm) for the flywheel bolts.
I was told the Exedy Cushion Button will allow for everyday driving yet handle track use extremely well too.
i got cushion button they are tops. great for everyday driving
+1 for C's. May take a while to get used to it tho as the throw is about as short as you can go.
You may find that you need increased effort to shift as it gets tighter because of the leverage point or something about how it works.
I love it but its personal preference i guess.
I've got the Tomei short shifter, really good, short throes, but the nylon bush/sleeve on the very bottom of the shifter is worn, and loose - need a replacement. Does anyone know if there's a Tomei service kit available? It just adds an unnecessary amount of slop to the shift.
ash, why didn't you like the short shifter?
dan, they will only be worse on the box if you bang it in all the time...
I had one on my BMW and it, along with the Momo Corse, were the best mods ever (that includes a built motor for it!)
It makes finding gears harder was the main thing for me
When i was racing a lot at Calder/Heathcote i found i was shifting faster without it.
Also i was missing gears far less as when there is a short throw, you have to be precise everytime.
I also was out-shifting the box sometimes i think, as it would crunch horribly. Shifter removed, never a crunch.
And it wasnt my useage of the clutch :)
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
