hey guys im trying to get my car back on the road and need some coin so need to clear all this shit out the garage.
HKS Direct Bright Pressure metre.
brand new in box open to test fit comes with all lines and mounting stuff.
mechanical so no control unit needed can be used for exhaust,manifold,fuel and oil pressure.
just bought this but no longer need the pressure gauge.
Black in colour and lights up blue.
worth $300 plus.
$150 delivered to your dooor
RPM 4 point harness.
Bought this with my bride but dont need it.
it was made on the 11/12/06 so i believe its got 10 yrs from that date.
$140 delivered
GFB Bleede valve.
used
$40 delivered
Omori Water Temp Sender.
no lines.
$25 delivered.
Kuhmo Ecsta Tyre
Brand new.
17" by 225 i think will check that.
$70 pick up
HKS TO4E
Just been serviced by ATS and new compressor wheel put on it
$1200 ono.
any info wanted on the turbo please call Adelaide turbo services (ATS) 8377 2511 ask for info on the T04E that is there owned by Matt W.
gauge sold
everything else still here.
    • Ah yep. I asked a auto electrician about getting a cheap rebuilt alternator vs a new one. He also said he used to it back in the day but it ended up costing similar to what a new one would and recommended getting a new one,.
    • Ah, to clarify if the car has already been tuned and has been modified and you want to go from a oem cat to a 100 cell or decat or vice versa.Are you saying that the car doesn't need to be tuned after a cat change if it's already been tuned?
    • This has been covered a bazillion times but google wet boiling point vs dry. Motul is only good when it's fresh, once it absorbs moisture it gets pretty average very quickly. So as above, make sure you change it if you're going racing. I run the Endless brake fluid in mind, but only because a mate is a distributor and it's cheap. It's not quite as good as SRF but I'm running 380mm rotors on a Skyline so it's not like they get hot.
    • That's the thing, they still add it and it makes fuel cheaper, implying adding 10% of it drops the cost of 91 by what, 5c a liter? I remember when it was barely half the price of 98. Because you know, 85% of what is in the fuel is way cheaper than 91 fuel is by volume.
    • Auto electricians that do repairs on automotive AC systems can source service kits. I don't know where they actually source them. I do know that there is one available for the R34 comp that I would need it for. If you have to pay someone to dismantle, clean and do needed repairs and fit kit contents, then you'd probably end up spending a good fraction of the cost of a new one. I would not be paying for that, because I would be doing it myself. My mechanic (bro-in-law) will happily source what is needed. Back in the day (like in the 80s and 90s), rebuilding an AC compressor was the standard approach, same as for starter motors, alternators, etc, because new replacements were v. expensive. After the China manufacturing boom and the rise of the disposable approach to everything, people just started throwing broken/worn stuff away and not rebuilding things.
