  • 1 month later...
Fair suck of the sav. How many 350kw GTRs run low 10s? I would say it has less to do with a driver having a clue and more to do with the fact that the cars tyres and suspesion setup, ride heigts etc are setup for drag racing. Then there is the matter of whether they are runnig std gearbox.
So saying low 10 with ... half a clue. No way thats a reasonable rule of thumb.
This is cool. Since I have a 350awkw GT-R but have never done a drag race I'll just tell people it runs low 10's when they ask (as they ALWAYS do).
yeah, it's a 10 second car for sure.....
........with a 14 second driver.
Sorry I missed the bit in the first post that said what tyres it would be on, who would drive it, what it would weigh, what gearbox was in it etc.... My fault - the details must have been hidden in amongst the 13 whole words in the post.
To put it another way, that power and a 1.45 second 60 foot could run a 10.3 - 10.4 on its head. The fact that "owning a Ferrari does not a Ferrari driver make" applies to gtr owners has nothing to do with the car's potential.
    • It just depends if you're like me with a high level of OCD for doing something like hardlines, and highly critical of the little things, and then bugger all patience to get it how my brain pictures it
    • More than happy with the colour match Talking to the painter he recommended to give the top a few weeks for the paint to 100% cure prior to sealing it with the ceramic stuff Also, because why not..... I have a fancy pants Fluidampr harmonic balancer on order, the 2.5 engine uses the OEM 2.0 balancer off the old motor as the 2.5 balancer is a larger unit and doesn't fit clearance wise, which, because the two engines have different harmonics, isn't optimal, the OEM balancer does the job, but as the gear driven balancer in the bottom end is removed to fit a RWD application there is slightly more vibration, the Fluidampr helps with the harmonics that the gear driven balancer once took care of,  basically makes life easier on the oil pump and bearings when thrashing it around Hopefully the weather gets better soon because I'm keen for some cruising around, and currently, with the winds and storms we are getting, the amount of detritus being blown around from trees on the road isn't something I want to be driving around in
    • Meanwhile you could come down for a coffee tomorrow. Details in the events section
    • sorry dude i forget about the forum sometimes. sent you a pm
    • Hell yeah. It's not as if the path from front to rear is particularly squirrelly or otherwise difficult.
