I'm currently installing HKS adjustable cam gears in my RB25, the gear does not appear to line up with the original bolthole on the intake cam, can someone who has fitted these please give me some advice on how to solve this problem. I have done a search already and found nothing other than SydneyKids guide which does not address this issue. Also what does the VCT on the intake cam do and do I need it with the HKS cam gear?
Cheers Steve
https://www.sau.com.au/forums/topic/167837-adj-cam-gear-query/
have you bought two exhaust cam gears? Brand names gears have differrent orientations on the intake and exhaust.
check part numbers IN 2204-AN001 and EX 2204-AN002
Edited by URAS
Leave the VCT
It does what your cam gear is doing, changes the positioning of the cam, a: for better response, b: for more top end.
Difference being, it does it whilst the motor revs up. You set your cam gear once and leave it (Don't know how well you can get out, and change your cam gear whilst you're driving)
Just do the exhaust gear.
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
