hi gang,
as per: http://www.skylinesaustralia.com/forums/in...howtopic=161511
as some of you may or may not know i am trying to port and get the RB26 PFC working on the rb20 and rb25.
the main issue i can see with the rb25 is that VCT is not supported.
VCT is switched on aroudn 1800rpm and off at 4700rpm by the stock ECU and the RB25 PFC.
i have tried with my 25 PFC turning VCT off at 1900rpm (that is, only have it on for 100rpm) and the car was a pig to drive.
lag city and it felt like it was as flat as a tack to drive around.
so my known working solutions are as follows;
1) use jaycar controller / type of system
this involves a 3rd party device to be built and tested / setup
its manual and would involve some time, each customer would need to buy one and set it up to retain stock VCT control
2) dont do anything and leave as is
this would leave the car boggy / laggy and gutless. can we do something else to make it "normal" without VCT?
can we hard wire the solenoid on or something?
3) required part of the 26 hacked 25 FC is exhaust cam gear
how does this negate not having VCT, i know it replaces the physical cog but does it make it drive the same and take away the boggy/laggy feeling?
how does it achieve this, as far as i can see aftetrmarket exhaust cam gear just lets you dial in forward/backward, does that then negate VCT ?
any suggestions/ideas would be great
i wanted the ported FC to be plug and play, that is a customer buys or gets a 26 PFC
plugs in my custom loom, makes some changes on the hand controller and its ready to go
it idles normally, runs like factory 25 PFC and they can fang around or head to their tuner
if they have to use the jaycar box it requires them (or me) to build the box, set it up, test it etc
and they would have to instlal it onto their loom
my 26 FC is on the way from japan so it shouldnt be long (a few days before i test it)
good news is it looks like rb20 customers should have it easy as theres no VCT needed or other trickery
:P
https://www.sau.com.au/forums/topic/167846-request-for-help-no-vct-on-r33-rb25/
  • Replies 58
Hey Paul
I heard that Apexi are working on a replacement chip for R33 Power FC's because the damand is so high so we may see them readily available again in the near future...
I heard that Power FC's are still available for RB25's brand new but are more expensive... If anyone wants one new they can call Turbotechnics on 0249565466 who orders them Directly and are still available just a little more expensive because they are buying these NEC chips from wherever they can and are paying a higher price for them.
The info i get from this guy is allways very reliable but you never know i guess... Maybe the Rb25 PFC is not in such a great shortage after all?? this hype may settle down shortly...
Edited by Guilt-Toy
yeah well doesnt anyone wonder where people are buying the brand new RB25 ecu's and putting them on ebay ?? where are they getting them from?
I dont think someone purchased 2000 of them because they knew this shit was going to go down.
There may be delays on orders because they come from Japan when they are made but they are still being exported.
Hey Paul
yeah its true, even the AP engineering stuff is available if the customer orders quantity. The gear is all there but due to production costs they will only make stock they are readily selling, they do no want to be producing stocks to sit on shelves. At the moment they are producing to fill orders and until the orders warrant production of significant quantities the "discontiued" ones will stay that way.
Edited by URAS
the exhaust cam gear doesn't replace VCT. VCT is only active on the inlet cam. think of it like an adjustable cam gear with 2 settings (1. response, 2 top end), but it can switch between them. so it gives you the benefit of an adjustable cam gear (again inlet only here) without the compromise. the reason people may say that fitting an exhaust cam gear makes up for no VCT is that they both have a similar affect on performance. but ideally you want BOTH.
it just seems weird that the 25 is a pig with the VCT turned off... you would think there would only be a very small seat-of-the-pants difference... barely noticeable... afterall the 26 seems fine and its usually got another 100-200kgs to lug around... weird
Yeah.....
They got 10 in last week and had 15 on order so they are comming into the country directly from Apexi.
hi gang,
:action-smiley-069:
Paul
GTS-t VSPEC has been running an RB26 D-Jetro PGC on his RB25 over here in WA for quite some time now. He has retained the VCT and also made it adjustable (i.e. rev dependent switch point) by adding a third party switch (i.e. your option 1). I believe the point at which it activates makes significant difference to the power/torque curve.
Drop him a PM for further details :blink:
hey
ok things i know are that the 26 FC will work on the 25 and that we can make VCT work
its just how elegant is the solution for the customer. i wanted it to be plug and play for the end user
so they dont have to fiddle with external boxes etc. like for 1 dude its fine to have a jaycar/external box but for 100+ its a different story
Guilt-Toy your a legend !. Gave turbonetics a call, and they can get them new, like you said, they are using chips they can source and doing them by order in japan only. then sending them upon request. and if you get them thru turbonetics, u can get an australian warranty with them.
(oh yea, Quoted price was $1550. and a 4 week wait.
good work :blink: no rumor at all. problem solved for me. :action-smiley-069:
- CHeers
dale.
Edited by silverbulletR33
paulr33
Do a dyno power run with the VCT turnt on all the way to redline.
Then do a run all the way to redline with it turnt off.
Have a look at the huge difference. Where the two graphs cross, this is your switch over point.
Due to the amount of lag down low, this may well indicate, due to the cam movement, that it wants some more timing (And will most likely be able to be done without inducing ping due to the cam "profile" change)
You may want to leave it turnt off and attempt a change of the tune.
yeah i know about the changeover test point
my question is, can u tune the 25t and get the same results if you just unplugged say the VCT solenoid
that is, standard PowerFC, unplugged stock VCT, stock cams, stock turbo etc
like same midrange, power, response, feeling etc...
cos when i did my testing it drove like a pig
ie: unacceptable
if it can be tuned with the thing completely off, then im not worried at all
If the VCT is OFF when going for top end power, then you'll never get the same response (You've changed the VE characteristics of the engine down low)
So when unplugged you will never get the same low down response, BUT with a decent tune (More fuel/timing) it should see you getting back alot of your response.
When you change cam profiles, it adjusts the timing maps drastically, that is exactly what you've just done.
Most likely, down low, you might be running a touch leaner or so the o2 sensor might say.
Throw it on a dyno, and see what you can tune in.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
