Just a side note...i found that after letting my RB breathe with an exhaust it is a lot easier to drive around off bost - thus improving my fuel economy - as i can use the natural torque of the engine around town, leave it out of overdrive around town so the power doesn't go to the slush box (lock -out torque converter) and whalla - i have better fuel economy :P
Ive been peddling mine around town on low boost (18psi) and have only let it go a few times. 330kms with just under a quarter left in the tank. Im wrapped. Should get 400kms to the tank around town.
fo sho it is
i just clocked out 280KM on my last tank i jsut filled up 44USD a tank
Thats sweet F/a cheap. 60litresx 1.35 = $80 , $44US is CHEAP.
Now I am lucky. I live in the BEST place in OZ to own a Stag. Ask Ska.(thats funnnnniieee) The roads here were built by the inventor of the corkscrew, and the only way up, or down, is at about 20 degrees.
I get 15/16l per 100 average. At my age I consider it cheap entertainment.
I used to, but dont smoke now. Two or three packs of fags. $30. I brew my own beer and love it. $30. That covers my petrol.
I have always said "Buy a Bombadoor and Gas It".
As the Jap ads say, it is a great family (business) waggon with oomph.
haha tell me about it hugh
we went up mt tambourine when we were in qld last
plenty of rubber up there :)
When and what colour?
The rubber cant be mine, 4WD, prolly my S13 Drifter son.
... leave it out of overdrive around town so the power doesn't go to the slush box (lock -out torque converter) and whalla - i have better fuel economy :wub:
Is that right? I'd have thought running 4 gears around town would help with fuel economy instead of the other way around?
Same here, I thought letting it run in 4th round town will save on fuel, due to lower revs etc.
Mine sits around 1600rpm when sitting on 50-60km/h but is up over 2000rpm in 3rd (I know cos it doesn't hit 4th until the transmission warms up).
  • 3 weeks later...
Now you are lucky.
Over here in NZ where we pay about $1.65/L, it cost me just under $100 to fill up from empty, for about 300kms from the tank. That is for cruising aroung town. (~14-15L/100km).
My highway figures are good though, at 7.5L/100km.
All this from a non-turbo stock standard RWD.
Hate to really disappoint you guys with RB25 Stageas, but the 260RS gets almost 400 km from every tank. which calculates to average around 14-16 l/100km.
i assume the tanks are the same size, so the RB25's must be gas guzzling things!!!
Edited by Herbietjh
no...cause in townsville (the land of 70kmph roundabouts, you are forever accelerating from 50km/hr to 70.. you are in overdrive, and so when you accelerate gently the torque converter takes up all the power, (you're in a high gear, with no torque lock because you have been back off the throttle). so you keep gently squeezing on the gas until you acelerate, but instead of the gears droping down into 3rd, it starts to lock up the torque converter, now if i was at 40 accelerating to 60 this wouldn't be an issue, but that extra 10km/h means that it doesn't drop down. You will be at higher revs so the turbo is ready and waiting to spool up, and it does,
so instead of accelerating at 3000rpm
with no boost in 3rd gear
Using natural torque of the engine at 0psi and a more acceleration friendly gear ratio
with the power going directly to the wheels cause the lock out torque converter is 'locking out' the slushiness
you inf act are accelerating at 2500rpm
with 10psi boost,
the stock ECU dumping fuel into your cylinders
and all the power going no-where except to the O/D
If i am ever in a straight line for a bit or cruising around, i slip it into O/D for a bit, but on approaching twisties i slip it back into 3rd
I am also experiment with keeping the A/T mode slector on POWER mode so that it shifts down instead of building boost, but i am finding it still seems to hold on to 3rd a little too long when doing the straight and narrow thing....although this may just come down to fine tuning my driving style when in 'POWER' mode for the auto trans.
It's like Ska said when he was doing his fuel efficiency testing, he selected lower gears going up hills instead of a higher gear with more boost.
Boost is what kills your fuel economy, not rpm.
higher revs with no boost
is better than medium revs with lots of boost and no power transfer to the wheels :)
I thought that too when I calculated 14-15L/100 for around town, but my highway figures turned out at 7.5L/100k, which could mean an optimistic 800km from a single tank.
Must be all that stopping and starting stuck in traffic, pushing up the figures.
Or maybe the missus is trying to take everyone on at the lights!
Whats the best way to better the fuel consumption without driving like an old lady? Extractors and a big bore or a computer tweak?
Edited by BlueStagea
Sliding Performance rb25 highflow turbo ;)
that way you dont ramp up on boost until a bit later in the rev range (not a huge deal of difference compared to stock turbo)....
by not getting onto boost until slightly further up the rev range (200rpm?) you save fuel in city traffic
good excuse anyway to highflow the turbo :)
we dont get non-turbo versions in Australia, sorry cant help.
replace the Oxygen sensor
replace the fuel filter
get a SAFC and have the airfuel ratio dynotuned
use a good engine oil
check the cat converter and make sure it isnt blocked
use hi-RON fuel
strip off some weight (not you, the car!)
    • Standard GTRs are boring and there plenty of them, do what ever you want to it and just remember nothing about them is cheap anymore and if you’re picky about how you want things done it gets even worse.    if it’s an n1 or something very limited then maybe care more about it’s heritage
    • Alright guys, I've got good odds the motor survives due to a majority of spare parts. Who's taking bets on clutch, who's on transmission, and who's go diff? Happy to also take bets on if it still overheats in traffic or not 😛     Car looks amazing by the way. I've never been a fan of R34 rears, so really, I don't think any body kit etc solves that for myself, but the front end looks amazing!
    • As an ex-skyline owner Going off how these things are now "modern classics", I would keep the twins and just "refresh" bits that are required for reliable power and have a car you can take out for a cruise whenever you get the itch As a idiot who cannot leave things alone Going deep into the "rabbit hole" is a easy thing to do, as previously mentioned, once you start it becomes a slippery slope, wirh lots of supporting mods, and possibly rebuilds, and unless you have a bottomless pit of funds, the car can spend most of its life sitting in the garage,  broken, waiting for parts, or building more funds For a classic like a R32 GTR Basically, a reliable OEM+ refresh, that isn't a broken garage queen, is alot better than a car that you build, then break, then fix, then break again And it isn't just the engine you need to worry about, these beasties are getting on in age, and all parts are getting, and have got, expensive, the days of picking up cheap replacement engines and other driveline parts are well and truly over The funds not spent on going a single with quality parts, and with all the other other bits required to make it happen, could be spent on refreshing alot of other parts A wise man once said "If you cannot afford 2 GTR's, you cannot afford 1", I also believe he said this about 20 years ago when you could pick up a clean R32 GTR up for around $20k My advice for a R32 GTR (the one and only true Godzilla in my mind) is to think holistically about the whole car, the body, the power train, the suspension, the brakes, and the driveline SAU is a wealth of knowledge with decades of Skyline experience,  from stock, to OEM+, to modified to varying degrees, to full on or weekend or dedicated racecars, as well as full on money pits that rarely leave their garage Treat the old girl nice and give her what she deserves, you are a lucky man to own such a classic car
    • For that price you could buy the hypergear turbo (big fan as I run one) and the Haltech ECU..
    • +1 for the Elite 2500. Get some new knock sensors while you are at it (pretty cheap), look up the TAARKS Nissan knock sensor kit. You may also want to get new coils (R35gtr) while your at it (assuming your on stock ones), as they are a liability. Mine started right up and idled fine on the base map. Also go MAP over MAF, as said above, Haltech make this super simple right out the box. Another fanboy of DBW here, Outsider Garage from your neck of the woods make some nice conversion gear for the R33 (that’s where I got some of my gear from).
