the O2 socket has a gap you can slide the wire out of i have one, best investment ever when i need to remove it... But go to your local parts store
its like 20 bucks for hte socket
I see, thought it was one of those $100 tools which you use once every 2-3 years! Will check the local Repco and get a O2 sensor from them too. One size fits all?
thanks for the tip .. I was really not keen on removing that heat sheilding to get a spanner in there.
yeha
but unless you cut off the lead fmor your OLD o2 sensor you cant use a socket
other option is to take off your o2huosing and then remove with a wrench.
ther eare two sizes that i know of
i got the larger one
it has worked on everything from Mecedes, to hondas, to mitsu, to nissan
Thats exactly the economy my series 2 gets. I earthed the boost solenoid last week, so am interested in how that affects economy. I have a theory (untested) that having higher boost coming on early will assist in moving the weight of the Stag up to cruising speeds easier, so therefore the fuel consumption my even out, or even be slightly better. I will let you know how it goes. It certainly helps the driveability, and means I dont have to sink the right foot as hard as before.
I havent done a trip in the car since getting it a year ago. I was hoping to come up for the skyline show & shine, but had to miss that in favour of the rugby test.
Brief Update. Fuel economy the same as before (420kms). This is good news, given the improvements in mid-range power and torque. Not sure whether one trip is enough evidence to test my theory, but it certainly hasnt gone backwards. :(
lol not me a mate dreamed it up (should open a tool store i reckon), but it does work pretty well, since we cut it down short enough to be able to turn it more easily down on the rear dump pipe which is really tight. Pretty sure it was 22mm which was the other bonus.....who is going to miss a 22mm ring spanner?
try your local autoparts supplier other than the ones mentioned above, i mean small ones they might have it or they will be able to source one for you.
Tried spanner, couldn't get enough "purchase" to twist.
I've ordered a socket from ebay, $22.80 delivered. Hopefully I'll get it next week. Once I have it, anyone in Adelaide need to borrow it, PM me :P
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
    • I somehow quoted my post instead of editing it. I regret nothing.
    • STOP GOOGLING FAB9 MAKE BORG WARNER EFR KITS FOR THE NC. THEY PACKAGE AN EFR 6758. DO NOTHING ELSE. CAPS INTENTIONAL. THE BEST RESPONSIVE SETUP EXISTS FOR YOUR CAR, AND HAS BEEN PROVEN FOR QUITE SOME TIME NOW. IN B4 "BUT I WANT EVEN MORE RESPONSE, IN A SIMPLER, MORE RELIABLE PACKAGE" WHICH IS A LS.
