Stagea Fuel Economy
Why would you skimp on something as important as engine oil?
x2
fully synthetic please
nulon hi-tech fast flowing has been going pretty well in mine but its not a true fully synthetic (only class 3, barely fully syn)
will be changing to Gulf Western S6000 Sougi next week, its hard to find but its as good as Motul 300v Chrono apparently but only $60-70 for 5 litres
and its nothing like the cheapo $12/bottle stuff supercheap sell either
worth looking for really
ive posted mods a few pages back,
got pod, fmic, boosted slightly more then stock, dump off the turbo, gutted cat and hks exhaust, thats about it.
i dont drive her too too hard but i still give her a push here and there....
Nice one. Pretty surprising you haven't got it retuned or anything. I just filled up today. 410km and 54L (13.1L/100km). Not brilliant.. I really want to get a wideband AFR meter and see if I can lean it out a bit more for normal driving. Hardly gunned it at all during the last tank.
I know I know what you mean. I have 3 cars and the other 2 uses Royal Purple which is not cheap. Although I use cheaper mineral oil for the Stag, I change it more often. Still that's no excuse! :blink:
Well now that one car is going, I thought I'd use a better oil on the Stag so hence the change.
my S2 gets about 320k's per tank, maybe alittle more if i am highway driving. main reason is that i have a gtr-s, front mount, exhaust,stock boost, stock maps (nistune fitted).
once i get the board tuned i'll find the economy will go up dramactley.
Thats pretty low for a series 2, especially with those mods... Hope the nistune helps dramitcally
...I also would like to say, i really hope to see under 10l per 100k after my nistune install, hi-flow panel filter and turbo back exhuast....
How has fuel economy gone since the nistune? I have very similar mods and am tempted if it's going to reduce my fuel bill dramatically.
Edited by webng
626kms 78.8L (not impressive, but it was fun :( )
As an aside, I would not recommend running so low on fuel in an M35, I accelerated moderately up a minor incline, only to have the engine drop out on me for a split second due to a lack of fuel picked up by the pump lol.
  • 5 months later...
G'day,
Just picked up a std S2 RS4V and drove it back from sydney to melbourne.
From Goulburn Caltex to Caltex Avenel 99% highway driving at 110kmph we used near on exactly 60lts of 95RON for 557km (odo actualy read 570kms due to smaller than std tyres fitted).
However a drive (correct tyre sizes) around town and highway, pretty much a 50/50 split saw a drop in 100kms of economy ie 470kms for again pretty much 60ltrs of 95Ron Caltex.
Deduce from that that maybe a drive 100% round town means 370km per 60ltrs - "Crikey"!
And also light comes on at close to 60lts used - Are these things 65lt or 68lt tanks?
Thought I'd add my readings.
"Safe Boating",
Mike.
675 km's for 75 L y'day
roof rack, windows down, air con on, no pussy footing
gonna fit a fuelstar fuel catalyst soon too so will get back to you on that when I do
The available evidence would seem to indicate these are a con. Did you fit one and has there been a long term difference in consumption?
G'day,
"Safe Boating",
Mike.
grab yourself a new oxygen sensor and it should help out a bit, the sensors only have a limited lifespan and rarely get replaced in japland
i also run 95 in my stagea due to the exorbitant price of 98 in tas but it does lack a bit of power compared with 98 and i get slightly less fuel consumption with it too (the ecu will run more timing on 98 = better fuel economy)
no one makes an aftermarket o2 sensor for the s2 stageas (rb25 neo same as r34 gtt) so its either stock nissan one for about $250 or get one for a s1, r33 gts-25t, n15 sss pulsar and cut and re-crimp the wiring using your old plug
Pipster11 thanks for the comments.
I have read all the comments on fuel economy in this and other threads, "helpfull info - thanks everyone" (O2 sensor change duly noted).
The 570kms that I got, all be it highway run, seems to be quite good when compared - so I am more than happy with it. Had a bit of weight (4 x 19x8.5 with tyres) in the back aswell.
It's daily route will be 85% highway 15% town - hoping for at least 500ks a tank normal driving.
Cheers.
    • Great to know! The guys from The Skyline Shed are going to sort it out and send what I ordered anyway. Turns out their supplier sent them the wrong stock.  But it's good to know I "can" put this in if needed
    • You do not need an LSD oil in any stock (non-GTR) diff, even if it is an "LSD". This because none of the (non-GTR) LSDs are clutch/friction type LSDs. Either viscous or helical - neither of which require an LSD oil.
    • Hi everyone, I bought the Redline diff oil and the seller has sent me Redline 75W90NS even though that’s not what’s pictured.  I’ve already booked a hoist to go and change my diff tomorrow but I’m not sure if the NS is ok for the rear diff in a R34 GTT I think the NS does not have any slip modifiers so would that be an issue?    thanks in advance
    • Not easy to find pics from 15 years ago, but here is a partial one. Keep in mind that it curved immediately from the airbox, then kept a straight line for the MAF to read correctly, followed by a 45 degree bend straight down to the turbo. This connection was the most difficult as it had to twist as well as bend to meet the almost vertical straight section of the intake.
    • Yes, well, wrt a wheel alignment, there are two types. Either: You have very little added adjustables, in which case the alignment can be done by anyone in any tyre shop or equivalent, and will only take 30 minutes, and so there is no reason to even consider leaving the car there. OR: The alignment is a major exercise because you have adjustables everywhere and so you will need to be taking it to a shop that is skilled and experienced at setting up race cars and the like, and you won't need to worry about leaving the car there.
