M35 averaged 9.69L/100km in the last week. Lowest was 8.00L/100km between Mildura and Wagga Wagga. That includes 3 days of city driving around Canberra so I'm pretty happy with that. Return trip was a bit thirstier due to head wind, more overtaking and.. urgency.
8L/100K is impressive. You running E10 or something?
on 98 i got 606 out of a tank,
it was a mix of city & highway,the mods i have are high flow turbo(stockish) high flow cat hdi inter-cooler and a k&n high flow panel air filter.ill be doing the same trip this weekend and ill try some 98 and see what i get this time around.
Screw you guys, I'm averaging 14.78L/100kms, according to the app on my phone. Best run was 12.37L/100, worst was 18.07L/00, but I think that included the drag day @ WSID.
Then again, I don't drive for economy.
+1 to this , I enjoy 2nd and 3rd gear too much.
I can understand C34 owners getting upset when M35 owners rub the C34 noses in our glorious 5 speed auto box, more leg room, less cabin noise, better weight distribution, newer technology, better handling, better interior, better ride, more room in the back, better stock power and better fuel economy....... :devil:
Most of what you said was true but I gotta say you can keep your "glorious" 5 speed auto gearbox. Its like this :- the VQ25DET is fantastic, but the laggy gearbox will keep you from really enjoying it.
I've owned both C34 and M35 - am back in a S2 C34 now, and my summary is as follows:
The ONE thing wrong with the M35 = drive-by-wire. I'm not sure if the drive-by-wire was the cause of the problem, but the gearbox was laggy as hell, and for me it really hurt the car.
Yes, the M35 is newer, and better in almost every way, except that in a stock for stock comparison, the C34 auto & throttle is WAY more responsive.
When I sold my M35 I stupidly bought a 2007 Ford wagon - what a heap of junk! After learning the hard way, I sold it after 3 weeks and returned to a stagea, but went for a C34 due to the lower price and lower running costs.
Both cars are great to own and drive - the C34 is more responsive and more "raw" (I think you feel more connected with the car), while the M35 is more comfortable and more luxurious (while being actually faster and handling better).
While on the topic of fuel economy, the difference between the two cars isn't that great:
My M35 got ~12L/100km city & 9.5L/100km highway
My C34 gets ~12.5L/100km city & 10.5L/100km highway
The M35 has different gear/diff ratios which helps a lot on the highway (the extra gear does make sense here).
Always get 400-450k's to a tank before the fuel light comes on in our S2 C34 with Neo RB25t. However, last tank we only managed 350k's before fuel light came on.... any ideas why? For the first time ever the Engine warning light came on too.
dead o2 sensor
or dying coilpacks
or boost leak
I'm at nearly 400ks for this current tank and it's getting damn close to fuel light time. I reckon I'll just nick 400 when it comes on. I would expect better for the driving I do (works out to be around 15l/100ks).
Mostly suburb driving. Still haven't figured out what my crappy miss is. Starting to lean towards coil packs. Might try gapping my plugs down and see if that helps a bit.
how do you test the o2 sensor?? i have been getting 350k's per tank for awhile now.
The best way to test them is is go here - http://www.skylinesaustralia.com/forums/topic/135194-ntk-nissan-lambda-sensors-o2-sensors/page__p__2513840__hl__sensor__fromsearch__1#entry2513840 - buy a new one and replace it.
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
