I was doing around 300 a tank (city) with a 1400 idle in N, and burnt transmission fluid. After an idle reset and transmission fluid change i got 450kms (country) out of 3/4 of a tank so looks on track for the 600kms per tank (country) you NM35 guys are getting. Will be interesting to see what i get city.
IMO anyone using more than a ?W-40 oil on a stock or near stock motor is needlessly wasting fuel. I'm currently running a full synth 5W-40. I will try a ?W-30 next change (tho one of the guys here (maybe Scotty NM35?) said that some engines are noisy with 30).
not long had my series 1 stag - been averaging 14/100 - mostly driving like theres police behind me apart from those odd blasts to get the chatter going :)
going to do o2 sensor as I doubt its ever been done - car is on 154,000
anything else I should be looking at to get the fuel use down a touch?
For the S1 Stag
Change coolant temp sensor, o2 sensor, Air filter, Fuel filter, Clean throttle body/plenum, Put air in tyres, check cat and mufflers, Check afm, Change oil, thermostat, coolent. spark plugs etc
Just the usual maintenance, everything adds up to better fuel economy i believe. My old VS used to get 9/100 because i kept up the services and changed the things mentioned above. Also always run on 98, i found it to idle better and was smoother on gear changes.
In the stag I'm getting 11-12/100 it used to be 14-16/100 it didn't really matter if i was on 5 or 12psi or how i drove. Still getting 11-12/100 since my last post
Edited by OS80RN
well driving back from brissy to darwin, sitting on 130km/h (120 buy gps) i got 580km out of the tank, that is it as in the car stopped :P at that speed from when the fuel light came on we got another 80km's before the car ran out! that's with the boot chockers 2 adults and 2 kids and about 150kg in the boot!
extremely happy with how the car went on such a long drive! The car still runs way to rich, the whole back of the car is yellow from over fueling, and believe with a powerfc and getting it tuned for economy at 80 100 and 130 that it would be even better.
you may also want to look into new o2 sensors
that should help lean it out a little at cruise speed
and there are probably better ecu options than powerfc
2nd hand powerfc for the price will be fine, didn't think about the o2 sensors, have 2 in my vl with the to4z kit, should change them I guess
just done my first full tank of 95. i've got a vq25dd i got 600km just as the fuel light came on, then went another 50km before putting more gas in.
400km of that was done with a full boot and family trip away up and down hills in twists and turns. Loving these wagons! bit more expensive to run than the 323 hatch, but the power is there to move this tank when i need to. 100km drop it into 3rd and its just as the vct starts to work, ans shit you can feel when the cams work.
Just clocked my last tank on vpower using 14.82/ 100. Devistating.... Just changed o2 sensor and reset ecu . see how it goes this week. The old sensor was totally ruined black and dark brown at the tip.
I've just started using the fuelio app to track fuel usage it's pretty good :)
My car gets almost 10% better fuel economy on United 100 octane than BP or Shell 98.
I just eek out 400ks on 98 but make it to ~440 on 100.
I've tested over multiple tanks on both and the results are fairly consistent. I wouldn't have thought there'd by a that much of a difference.
I've been using it for a while now, I like it.
    • Thanks again, really helpful chap from alpha omega wanted to speak to me, little concerned if this is meant to he aero alloy/ airospace quality and car sitting on drive has caused this.  Airplane are subject to much more changing temp and conditions than road salts! My caliper, many other components much older have surface rust but never eating part of the metal   Had I not seen it , could have been a disaster! specifically on rear part of bracket coming off like biscuit will update on what they say, helpful people so far
    • January or Feb is it booked in for turbo fitment?
    • The MX5 has had some annoying rattles in both front doors over bumps So I installed fancy pants door bushings, which stopped all of the rattles with the windows up, but........with the windows down there was still rattles, so after some googling,  and a chat with MX5 Mania, I got some new door to glass weather seals, all the rattles, windows up, or down, are gone now Shout out to MX5 Mania, the weather seals were on sale, and when I head to Dural to pick the up they even fitted them for me for free I did see a "really" nice Blue NA sitting out front   and this Black NC PRHT that looked like it has sat in the sun for its whole life and never had a wash, the clear coat was non-existent, an it looked horrible, really horrible, but, it had a nice turbo kit with over 200kw, the thing went like a cut snake, bagging the rears through the gears and dosing like a champ 😍 But, as I've always stated, I am keeping my NC na, I'm happy with the current power the car makes In other news: MX5 Mania do a drive in drive out turbo kit, the only minor additional part recommended for boosting my car, as it sits now, is a oil cooler, and that bonnet vents are definitely required for track use Aftermarket version look a bit to "racecar" spec I wonder how Focus RS bonnet vents would look?????
    • Paint is only structural when applied to the outside of Chinese and Indian cars. Otherwise it should never be present between mechanical joints that were intended to be metal to metal. Pain slips, slides, cracks, compresses, and add thickness that wasn't intended to be there. It comes firmly under the category of "just no".
    • appreciated it thanks   There are threads on the adaptor. I rear re anodising but didn’t know it will reduce strength   re mating services needing to be flat/ not painted, why would that be? I am devastated as car been off for a year, fixed power steering then installed bm57 master cylinder and just before driving it this came up. So annoyed   worried and afraid to drive it, no fun caliper coming off
