:D You don't have to drive slowly to get good economy mate.... just efficiently :)
although I guess it would be easier if you had that operation to remove the cinder block from your right foot :)
Edited by iamhe77
Well its going to be very interesting to see a before/after fuel econ for the Stagea after we get it Nistuned. Obviously we will running a bit more boost but the mix should be a bit leaner - so yeah, I really cant wait.
When I got my Nistune install and tune with the gcg hiflow (stock SMIC) I went from 130rwkw to 194rwkw and still get about the same distance to a tank - around 400-430kms. So yeah, I think it worked for me :D
Went down to nowra on monday mostly freeway driving I only got 570 out the tank and I still just under 10litres left wen I filled up best liters per hundred I got i think was 11.8
You have to learn to be lighter with the right foot Damo. LOL
Cheers
Andy
i was sitting at 250kms at exactly half way - nearly stock rs4s
mostly city driving too, was prob on the highway for 50kms
anyone know if there is a cheap replacement to the neo o2 sensor? like how u can use a falcon one for 33's
i dont really wanna pay $200 from kudos motorsport for a nissan one
Pretty sure they're the same; I used a Bosch part, can't remember what the part no. is (I'll have a look for it) but I just called Sprint and asked for the Bosch EGO sensor for an EF Falcon lol. Then cut & solder plugs. Sensor cost ~$70.
Edited by DaveB
You can use the falcon one - theres a thread on it in the DIY section.
Ah yeah that's right - this one
rad, i should have read on when i read it the first time
looks like my next purchase is gonna be one of those :)
cant wait
looks like 450kms from this tank hopefully (its been raining = mad sliding action)
my Stag (S2 RS4S) seems to do pretty good on the highway
a mix of 50/50 city/highway returned ~ 11.9L/100km (42.9L for 359km)
and a 20/80 city/highway split (although this included some squirts through the twisties near Berry/Kangaroo Valley) and my fuel guage was on the low side of the half indicator for ~ 300kms.
not bad if you can keep the right foot in check, lol
I got a genuine Nissan one off Ebay for something like $120 delivered about 18months ago. I don't mind paying that little bit more than the generic bosch ones as at least you don't have to cut the plug.
But I wouldn't be to worried about 250kms on 1/2 tank. Thats really not that bad at all would have to see what you got after the rest of the tank is gone.
yeah, have emptied a couple of tanks now, 1st full take = 13.9 l/100, 2nd tank 13.4l/100 so im pretty happy
just got an ecutalk and it will show instant fuel consumption :rofl: and o2 voltages too - seems its getting a bit lazy
cruising at a constant speed of ~60 its getting close to 9l/100, yet to a bit of highway so im not sure what im doing at ~100kmh
is there much difference in economy between turbo and NA on a vq25?
Depends on how you drive.... but on the whole I would say there would be a significant different considering the VQ25dd is direct injection and runs a much higher compression than the VQ25det.
Edited by iamhe77
    • Result of another R35GTR build. Similar specs as above except this is running our bigger size SS-2 profile option. Made similar power except this car runs on Pump 98 fuel. Build specs are: Nissan R35 GTR 2015 model stock engine and box. ETS street intercooler boost logi intercooler piping with tial bov, boost logi turbo inlet pipe ID 1050 injector DW 300C fuel pump Decatted oem down pipe and y pipe& HKS exaust 3inch intake pipe Upgraded actautors HyperGear SS-2 high flow option Final result is 639whp / 477wkws hubs, Ron 93 / P98 fuel at 20psi.
    • Duncan:- it affect both sides.  Driver side is worse.
    • That seems like a very special issue!  Does it affect both sides? Either way, I would disconnect the driver's side switch and see if it still happens, noting that might require removal of the whole door card which is a bit of a pain (it does on V37 and HY51)
    • MBS206:- The windows start to slowly open themselves. GTSBoy:- Battery is new since Dec.
    • I currently have a 2008 370GT Coupe, with the big brakes (Akebeno if I'm correct), and Its coming time to get new pads. Previously, I had a 2003 350GT Coupe with the stock sized brakes, not Brembos. I had custom wheels on it that were pretty open to the brakes, and when I first put the wheels on it, the rims where completely coated with brake dust. A few years after adding the new rims, I needed to change to pads on that car. I didn't do any research, but I told the mechanic of the problem with the brake dust. I also told him I didn't track the car or even drive around the streets harshley. But the dust was an issue. The mechanics changed the pads to a different compound, and the dust was GONE! The other change I noted was that when coming to a complete stop, instead of having to press harder on the pedal as I approached 0kph, I had to actually lift off a little to not come to a hard jerky stop.( My unfounded explanation is they became stickier as they heated by stopping ) Since I got my 370gt with big brakes, I noticed that that as I came closer to stopping, I had to press harder and harder to reach a full stop. I am not talking about hard, just harder. I brought the car in from another state, so when I had a blue slip done, I asked the mechanic what he thought of the brakes, and he thought they were brilliant. The only negative of these pads on the 350GT, was that they squealed when cold. So driving out of a shopping center carpark, it was a little embarrassing, as the brakes squealed, and I am sure people thought that I needed new brakes, when they were actually fresh. I have no idea of what type of compound they were on the 350gt, but whatever it was, I want to get the exact same on my 370GT. They weren't ridiculously expensive, and were replaced at the local JAX (which is no longer open), so I am certain they would be a pretty common big brand, off the shelf type/brand. My current mechanic suggested I need top get the rear pads changed soonish, but he suggested standard Brembo pads. Which I expect to behave the same as the current ones and not like the ones on the 350GT.  I don't think dust will be an issue on the 370GT. With the behaviour I describe above on the 360GT, does anyone have a suggestion of pad material that will act like the change I had done on the 350GT?
