Why would you skimp on something as important as engine oil?
x2
fully synthetic please
nulon hi-tech fast flowing has been going pretty well in mine but its not a true fully synthetic (only class 3, barely fully syn)
will be changing to Gulf Western S6000 Sougi next week, its hard to find but its as good as Motul 300v Chrono apparently but only $60-70 for 5 litres
and its nothing like the cheapo $12/bottle stuff supercheap sell either
worth looking for really
ive posted mods a few pages back,
got pod, fmic, boosted slightly more then stock, dump off the turbo, gutted cat and hks exhaust, thats about it.
i dont drive her too too hard but i still give her a push here and there....
Nice one. Pretty surprising you haven't got it retuned or anything. I just filled up today. 410km and 54L (13.1L/100km). Not brilliant.. I really want to get a wideband AFR meter and see if I can lean it out a bit more for normal driving. Hardly gunned it at all during the last tank.
I know I know what you mean. I have 3 cars and the other 2 uses Royal Purple which is not cheap. Although I use cheaper mineral oil for the Stag, I change it more often. Still that's no excuse! :blink:
Well now that one car is going, I thought I'd use a better oil on the Stag so hence the change.
my S2 gets about 320k's per tank, maybe alittle more if i am highway driving. main reason is that i have a gtr-s, front mount, exhaust,stock boost, stock maps (nistune fitted).
once i get the board tuned i'll find the economy will go up dramactley.
Thats pretty low for a series 2, especially with those mods... Hope the nistune helps dramitcally
...I also would like to say, i really hope to see under 10l per 100k after my nistune install, hi-flow panel filter and turbo back exhuast....
How has fuel economy gone since the nistune? I have very similar mods and am tempted if it's going to reduce my fuel bill dramatically.
Edited by webng
626kms 78.8L (not impressive, but it was fun :( )
As an aside, I would not recommend running so low on fuel in an M35, I accelerated moderately up a minor incline, only to have the engine drop out on me for a split second due to a lack of fuel picked up by the pump lol.
  • 5 months later...
G'day,
Just picked up a std S2 RS4V and drove it back from sydney to melbourne.
From Goulburn Caltex to Caltex Avenel 99% highway driving at 110kmph we used near on exactly 60lts of 95RON for 557km (odo actualy read 570kms due to smaller than std tyres fitted).
However a drive (correct tyre sizes) around town and highway, pretty much a 50/50 split saw a drop in 100kms of economy ie 470kms for again pretty much 60ltrs of 95Ron Caltex.
Deduce from that that maybe a drive 100% round town means 370km per 60ltrs - "Crikey"!
And also light comes on at close to 60lts used - Are these things 65lt or 68lt tanks?
Thought I'd add my readings.
"Safe Boating",
Mike.
675 km's for 75 L y'day
roof rack, windows down, air con on, no pussy footing
gonna fit a fuelstar fuel catalyst soon too so will get back to you on that when I do
The available evidence would seem to indicate these are a con. Did you fit one and has there been a long term difference in consumption?
G'day,
"Safe Boating",
Mike.
grab yourself a new oxygen sensor and it should help out a bit, the sensors only have a limited lifespan and rarely get replaced in japland
i also run 95 in my stagea due to the exorbitant price of 98 in tas but it does lack a bit of power compared with 98 and i get slightly less fuel consumption with it too (the ecu will run more timing on 98 = better fuel economy)
no one makes an aftermarket o2 sensor for the s2 stageas (rb25 neo same as r34 gtt) so its either stock nissan one for about $250 or get one for a s1, r33 gts-25t, n15 sss pulsar and cut and re-crimp the wiring using your old plug
Pipster11 thanks for the comments.
I have read all the comments on fuel economy in this and other threads, "helpfull info - thanks everyone" (O2 sensor change duly noted).
The 570kms that I got, all be it highway run, seems to be quite good when compared - so I am more than happy with it. Had a bit of weight (4 x 19x8.5 with tyres) in the back aswell.
It's daily route will be 85% highway 15% town - hoping for at least 500ks a tank normal driving.
Cheers.
    • Fk me, I guess next time I will try to use the onsite attachments feature. I find it hard to work with so far though because I can't move the images to where I want them to be. I will try to make a separate post with just images. As for lifting. The work I need to do for now involves the exhaust and engine mainly, so the arm covering the jacking points is not a problem. But I don't want to bend in the whole sill or underfloor by lifting the car at the original jack points. I found some rubber blocks, 125 by 125 with a 10mm wide and 10mm deep cutout, which I'm hoping will work for not hitting the jacking rail. The sidemember, as seen in the service manual, are the rectangular frame rails that come from the front of the car and go alongside the gearbox and downpipe. Those that get crushed inwards if you use them for a floorjack. They are already slightly bent in from being used to hoist by other people. I think cutting off the jacking points and welding or bolting on a reinforcement plate along the sill might not be a dumb idea. Or is it dumb?     A 2 post hoist is what I'm gonna work with, but not for any underbody work, just leaky engine and exhaust work so far. Depends on what else I find that might need immediate attention. For metalwork on the sills I think I'd just bring the car to a panel beater. What's your take on getting rid of the original jacking rails and putting reinforcement plates along the sills?
    • Yeah titanium always looks cool but I don't need that, just regular pipes would be fine. But I am really struggling to find any full hardpipe kit that is still for sale.
    • Saruthewhite hasn’t been on our site since November 2016 sorry mate
    • Note when Duncan says that, he means "when you're not using the correct lifting points on the sills, because you want to work on the sills. A 2 post hoist is not appropriate for everything anyway, and working on the sills is a good example of that, because the arms go under ths sills anyway. You're better off finding another way to support the car off the ground. Beyond that everything else D said is correct. Only the dedicated jacking points are the correct place to lift. Anywhere else is incorrect, extra caution and awareness must be used, etc etc.
