Stagea Fuel Economy
Ive just done the 1st tank in my RS4S and i got 13.55L per 100km and thats including some...enthusiastic driving :P
Bog stock standed WOOT
Edited by BR11GY
  • 1 month later...
Did you notice any improvement in fuel economy?
Cheers,
Fabio
I bought the K&N filter today so I will see how it goes.
On the M35 airbox there is a slot at the leading edge of the bonnet for cold air but on the front edge of the airbox there is another pannel that can remved opening up the front of the airbox. I have noticed on the V35 that this section is also open and sealed to only let cold air in. Would removing this section help improve the airflow and potential power? post-41854-1199513559_thumb.jpg
Cheers,
Fabio
Doesn't really make any difference to fuel economy, but does increase intake/ turbo spooling noise.
im managing to squeeze out 350per tank just before the light comes on.
and thats squirting it every chance i get - with a tuned 230kw.
I was only getting 200 out of a full tank previous - and driving like a grandma..
Have you worked out L/100kms now? And from memory there's at least 20L left in the tank when the light comes on. Your previous figures are about the worst I've seen!
nah, i probably never will, my screens been disabled when i took the GPS rom out and replaced it with an eManage.
yeh when the emanage was installed it was only tuned to get me to the dyno - anything above 4000rpm would just misfire and streams of black smoke out of the exhaust.
Cihan fixed it, so i could drive up to EDGE motorworks for a tune, and i've been getting heaps out of a tank now. with twice the power i do like my car now.
lol.... how so?
More air = more fuel
Well you claimed it was better!
Benefits!
#1 Noticeable ease in which the car accelerates and builds revs (even with the OEM dump pipe still on).
#2 More power. Definitely more power.
#2 Whilst the car does use more fuel when accelerating at a decent rate, economy has increased considerably. Particularly whilst cruising!
...I have MUCH better fuel economy thus far (will continue to test as the batch of fuel may have had something to do with it), ...
http://www.m35stagea...c.php?f=20&t=16
You tell me :nyaanyaa:
Was it really the fuel in the end?
Edited by ironpaw
In my mind, better efficiency = better economy BUT only if measured under same driving conditions. So for example, the new suction pipe teamed up with big exhaust should return better economy if driven as the same speed or rate of acceleration as before. The hard part is to not use the extra "efficiency" all the time which would wipe out most/all the economy gains :)
I am averaging 11.9L/100km on the highway, and around 14-16L/100km around town with the following set up;
RS-Four S Manual
3" Turbo Back Exhaust
Cooling Pro Stealth Intercooler
Nistune Computer
12psi Boost
(185kW @ All fours)
As quoted
"Whilst the car does use more fuel when accelerating at a decent rate, economy has increased considerably. Particularly whilst cruising!"
I do a lot of cruising.
How do you drive it? If you drive like Craig your economy will go to shit. If you cruise around 100kph, it will be better.
Doesn't your emanage have two settings eco and race? When you say heaps how many KMs are you getting? I'm doing dump pipe and front pipe fairly soon and I might consider doing the emanage afterwards...
specially if I can have two settings economical and race... my basic understanding is that emanage is able to control pressure of turbo as well as fuel, air etc....
Please let me know if you recommend that for someone that 90% of the time drives very easy and usually doesn;t go above 3000 rpm.
Cheers
Whats wrong with your right foot?
The Emanage doesn't have a boost controller built in.
If you want low down response, stick to smaller sized highflow wheels.
Dont go much bigger than the stock wheels unless you want to spend the coin on a gearbox build, injectors, fuel pump, intake and 3 inch exhaust.
Thanks Scott
I mean I'm doing the dump pipe and front pipe to improve the turbo lagging I don't really want to make my 1800 kg car into a race car but I wouldn't mind taking the turbo pressure up to it's limits with the stuck fuel pump.. (I believe turbo can go to 1.2 bar with the current fuel system)
If I install a boost controller don't I need to tune air and fuel to work accordingly with the new pressure? I though emanage would do all that for me at once nor two devices...
I saw some emanage units on ebay in US going quite cheap that's why I was wondering doing that....
Nothing wrong with my foot the other 10% surely it's to take the most of my engine.... commuting to and from work + suburb driving takes most of my driving...
Question: did you keep the cat in your front pipe? the guy from the shop was pointing that it's illegal etc... but how often are you gonna run into this sort of check???
Cheers
Edited by FHF
You had better do some searches, there is not that much information on here as only 3 or 4 cars have been successfully tuned so far. Im guessing that unless you can find a competent Emanage ultimate tuner up in Sydney, you will have to trek down to Melbourne for your tune.
The emanage ultimate wont improve your off boost economy by much, the stock map is pretty efficient. M35's run rich on boost, by leaning it out a bit there is a fair bit more power for free.
The stock turbo isnt reliable at the stock boost level, let alone bumping it up, save for a steel wheel highflow.
I have heard of heaps of Sydney-siders running catless front pipes, Down here were too scared of the plod. A 4 inch body 100cpsi metal cat will flow well over 300awkw I know for a fact. :)
In Sydney I haven't been checked once and I ran straight pipe for over 2 years. Was loud as hell. So long as you don't do anything stupid like sit in Liverpool crispy kreme carpark on fri-sat night. I only seen them check volume twice. Once on the old PAC. The other was near the airport. Still no emission check.
    • Great to know! The guys from The Skyline Shed are going to sort it out and send what I ordered anyway. Turns out their supplier sent them the wrong stock.  But it's good to know I "can" put this in if needed
    • You do not need an LSD oil in any stock (non-GTR) diff, even if it is an "LSD". This because none of the (non-GTR) LSDs are clutch/friction type LSDs. Either viscous or helical - neither of which require an LSD oil.
    • Hi everyone, I bought the Redline diff oil and the seller has sent me Redline 75W90NS even though that’s not what’s pictured.  I’ve already booked a hoist to go and change my diff tomorrow but I’m not sure if the NS is ok for the rear diff in a R34 GTT I think the NS does not have any slip modifiers so would that be an issue?    thanks in advance
    • Not easy to find pics from 15 years ago, but here is a partial one. Keep in mind that it curved immediately from the airbox, then kept a straight line for the MAF to read correctly, followed by a 45 degree bend straight down to the turbo. This connection was the most difficult as it had to twist as well as bend to meet the almost vertical straight section of the intake.
    • Yes, well, wrt a wheel alignment, there are two types. Either: You have very little added adjustables, in which case the alignment can be done by anyone in any tyre shop or equivalent, and will only take 30 minutes, and so there is no reason to even consider leaving the car there. OR: The alignment is a major exercise because you have adjustables everywhere and so you will need to be taking it to a shop that is skilled and experienced at setting up race cars and the like, and you won't need to worry about leaving the car there.
