M35 averaged 9.69L/100km in the last week. Lowest was 8.00L/100km between Mildura and Wagga Wagga. That includes 3 days of city driving around Canberra so I'm pretty happy with that. Return trip was a bit thirstier due to head wind, more overtaking and.. urgency.
8L/100K is impressive. You running E10 or something?
on 98 i got 606 out of a tank,
it was a mix of city & highway,the mods i have are high flow turbo(stockish) high flow cat hdi inter-cooler and a k&n high flow panel air filter.ill be doing the same trip this weekend and ill try some 98 and see what i get this time around.
Screw you guys, I'm averaging 14.78L/100kms, according to the app on my phone. Best run was 12.37L/100, worst was 18.07L/00, but I think that included the drag day @ WSID.
Then again, I don't drive for economy.
+1 to this , I enjoy 2nd and 3rd gear too much.
I can understand C34 owners getting upset when M35 owners rub the C34 noses in our glorious 5 speed auto box, more leg room, less cabin noise, better weight distribution, newer technology, better handling, better interior, better ride, more room in the back, better stock power and better fuel economy....... :devil:
Most of what you said was true but I gotta say you can keep your "glorious" 5 speed auto gearbox. Its like this :- the VQ25DET is fantastic, but the laggy gearbox will keep you from really enjoying it.
I've owned both C34 and M35 - am back in a S2 C34 now, and my summary is as follows:
The ONE thing wrong with the M35 = drive-by-wire. I'm not sure if the drive-by-wire was the cause of the problem, but the gearbox was laggy as hell, and for me it really hurt the car.
Yes, the M35 is newer, and better in almost every way, except that in a stock for stock comparison, the C34 auto & throttle is WAY more responsive.
When I sold my M35 I stupidly bought a 2007 Ford wagon - what a heap of junk! After learning the hard way, I sold it after 3 weeks and returned to a stagea, but went for a C34 due to the lower price and lower running costs.
Both cars are great to own and drive - the C34 is more responsive and more "raw" (I think you feel more connected with the car), while the M35 is more comfortable and more luxurious (while being actually faster and handling better).
While on the topic of fuel economy, the difference between the two cars isn't that great:
My M35 got ~12L/100km city & 9.5L/100km highway
My C34 gets ~12.5L/100km city & 10.5L/100km highway
The M35 has different gear/diff ratios which helps a lot on the highway (the extra gear does make sense here).
Always get 400-450k's to a tank before the fuel light comes on in our S2 C34 with Neo RB25t. However, last tank we only managed 350k's before fuel light came on.... any ideas why? For the first time ever the Engine warning light came on too.
dead o2 sensor
or dying coilpacks
or boost leak
I'm at nearly 400ks for this current tank and it's getting damn close to fuel light time. I reckon I'll just nick 400 when it comes on. I would expect better for the driving I do (works out to be around 15l/100ks).
Mostly suburb driving. Still haven't figured out what my crappy miss is. Starting to lean towards coil packs. Might try gapping my plugs down and see if that helps a bit.
how do you test the o2 sensor?? i have been getting 350k's per tank for awhile now.
The best way to test them is is go here - http://www.skylinesaustralia.com/forums/topic/135194-ntk-nissan-lambda-sensors-o2-sensors/page__p__2513840__hl__sensor__fromsearch__1#entry2513840 - buy a new one and replace it.
    • But it's much better to use a freedom unit that has four different possible meanings...
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
