not sure on the logic of more boost using less fuel haha.. but .. its worth a try.
I think I am going slightly mad.. but I remember saying somewhere that the stagea
o2 sensors are supposed to be replaced at 40 and 80 thousand kays..
so I bet a lot of people that have imported a stag at say 100,000 have never
had the o2 sensor replaced ever.
its on our list of things to do next weekend
calculated it currenty and its around 15L / 100km
hmmmm.... not sure if my o2 sensor was replaced when the conversion was done or not... may have to give that a try: it can't hurt (except my wallet). What's a replacement 02 sensor worth, anyone?? Will it be different for a '26??
I have run mostly 98 RON but running 95 RON doesn't seem to make any difference to the economy or running of the car.
Pity BP don't give any discounts on fuel. Which means that I have to keep going back to Woolworths liquor to get my discount vouchers so that I can get my 4c off the fuel..... well that's my excuse! :P
Caltex/Woolies Vortex 98 seems alright anyway. But every now and then I am probably gonna run a tank of 95.
yeah I've done the 02 sensor, they are dirt cheap just pick up the ngk one for the 33 gtst, it did help but not as much as I was hoping :P
Is there a discription of how to do his? Are the 33 O2 sensors the same for the series 2 as well?
I think you might need two for the '26, but for the RB25 they're around $80each, last I remember...
go buy an o2 sensor socket
and remove
it takes all of 10 minutes total to do it
There should be a description in the DIY threads, if not in the Stagea section then definitely in one of the other maintenance sections.
As Grant said, it's not a difficult job to do if you have the right tools, but due to exposure to heat, the sensor can be physically hard to remove. A bit of WD40 and some elbow grease is pretty much all that you need.
lol it is that easy too.
rb25 (series 1) direct fit is OZA395-E2
rb25 (series 2) just a generic one like EL ford, need to change plug
rb26 is OTD2F-P1P (rear direct fit ) and same again or generic for front need to change plug
Pity BP don't give any discounts on fuel. Which means that I have to keep going back to Woolworths liquor to get my discount vouchers so that I can get my 4c off the fuel..... well that's my excuse! :D
lucky for us we have a BP near us that does do 4cents off so thats my winner :rofl::domokun: I find with Woolies Vortex98 i dont get as many km's to a tank????
Good call, thanks Grant - would have thought of that a little late! :D
ive done it before not thinking
went and started swapping a turbo on a friends car he just got done driving.....really hurt
lucky for us we have a BP near us that does do 4cents off so thats my winner :D:rofl: I find with Woolies Vortex98 i dont get as many km's to a tank????
Hey Kirstie, which BP gives the discount and how do ya get it?
Cheers, Al
what size (external nut diameter ) are most of the o2 sensors?
I wonder if a standard deep socket would work?
yeah seeing where the sensor is .. its definately going to be much easier to remove with a dedicated socket. Right tool for the job and all that !
I still as yet have to get a consult cable on the car and check for fault codes - I have been so slack!
Is it just a matter of undoing the old sensor? Like a spark plug?
yeha
but unless you cut off the lead fmor your OLD o2 sensor you cant use a socket
the O2 socket has a gap you can slide the wire out of
i have one, best investment ever when i need to remove it
other option is to take off your o2huosing and then remove with a wrench.
But go to your local parts store
its like 20 bucks for hte socket
    • A locally delivered Infiniti have remote start installed but don't come with the remote start key. You need a new remote start key and they just need it programed. And this is different to making/programing a new key that just starts the car.
    • Cheers, and cheers for sharing so much of the build and also sharing the glimpse of what turns out to bring a lot of us poor decision makers together haha.  I do recommend learning more about how to manage it, if not considering getting a  formal diagnosis.  The discussion with the psychiatrist I got my diagnosis through was quite eye opening, things I'd not even considered to be ADHD related and hadn't mentioned were things she asked about out of the blue and were common themes with people with my flavour of ADHD.   It's not a label for people who are hyperactive and ill-attentive, there's more to it than that and some of it can be much more challenging or damaging - though there are of course two sides to the thing, and a lot of the stuff we have to go through and work on to live with it make us effectively "better" at other things as well. Aside from the fact that there is some argument I could have a bit of ASD seasoning in there (came up during the diagnosis, and neurodiverse things seem to not stay as a cookie cut) I suspect you need to learn more about ADHD if you are puzzled about how hyperfocus could possibly apply.  I *do* personally use "superpower" with quotes deliberately, but it's 100% an ADHD thing due to the exact reason that lack of focus is also an ADHD thing... Loosely speaking the inattentive side of ADHD isn't the inability to focus, it's the inability to control where the focus goes.  Not being able to sleep because brain is more interested in thinking about a stupid thing I said to a girl I liked 30 years ago, not being able to focus on work because my brain is more keen on putting together the torque management strategy we're going to try out with a drag car next weekend, not being able to focus on a conversation with someone I WANT to listen to and respect because there is a flickering light in my peripheral vision.    If I could just stop work and build the torque management setup right there and then I'd not hear anything else until it was done.
    • Maybe you should do some more reading.  Google positive effects of ADHD and you'll get your answers.  One of my personal downsides of ADHD has been talking before I think.   Maybe you have it too?
    • Excuse me for butting in....but which part of ADHD can be considered a superpower? I would have though it far more likely that some ASD comorbidity is more likely to be contributing to an ability to hyperfocus on something. ADHD being aimed somewhat in the other direction. My shed looks like your shed. My whiteboard list of unfinished projects has entries going back 15 years. I know what you're talking about - I just struggle to connect ADHD to the results being discussed.
    • Thanks for reaching out!  It's a blessing and a curse at the same time.  I'm undiagnosed but it doesn't take a rocket scientist to see it in me... I have more half started projects laying around my house, shed, garden, etc taking up space and money, destroying aesthetics than if I added up all of my mates projects together. But, ADHD gives me the ability to hyper focus on things that no mere mortal could even  comprehend.  A recent pool build is an example of that....  I dont know anyone else that would be dumb enough and focused enough to take on then complete something of that magnitude. I call ADHD a superpower but it can equally be completely destructive if not controlled and focusedon the right places. Addiction is a major concern to ADHD people and thankfully my addictions have been no worse than projects, XBOX, chocolate and being an arsehole! It's often hereditary and my 13 year old son is currently learning how to drive it at the moment. Keep lurking! If i can finally finish this bloody thing at some point it will be a win for all of us ADHD'ers! 🤪
