High flowing the stock turbo
Guest MFX_R33
How much extra power would u get from High flowing it... Just curious.. Will it reduce the reliabilty of the turbo.
I have got 205kw @wheels with this turbo at 17psi (this is pushing the efficiency limit of this turbo). The standard turbo has ceramic wheels, which have a tendency to de-laminate at around 14psi causing the turbine wheel to end up in your exhaust.
As far as it spooling up slower, I havn't noticed any difference. It spools very easily with almost no lag (as with the standard).
Jeff.
Originally posted by MYGTST
the standard unit is made by hitachi
garett quoted me minimum of $1000
benifits are you can run more than 14psi reliably
downside may take longer to spool up and it will no longer be ball bearing
and no they can`t convert it to BB iv been told
I'm not sure but do series 1 have BB?
Jeff.
Did you just get the compressor side hiflowed? It musnt be if u r spooling at 2500
I got both sides hiflowed ($1000) and im hoping for 200kw@12psi.
Starts spooling at 3000 full boost 3500
we'll see next week when i get her tuned on the dyno with the SAFC
Guest MFX_R33
My Hilux looks the goods, and has a nice tan leather interior, but it is no SR5 :D. Mine is a Grinner, ex-Repco delivery ute. Full time LPG, 1.8l, 4 spd. It's a slug but it looks ok for a work ute (pics on my site www.mfx.com.au under Team). Anyway I have a Skyline to go quick :D.
Jeff.
Jeff just looked at the pics of you lux and line the line looks mad!!
I really like the look. so different!
and your lux is great for a budget build as well.
how do you find the EMS is it as responsive as the the factory ecu how is it at low speed and rev's .
cheers
meggala
Guest MFX_R33
Thanks all :cool:
Meg. The EMS is good if it is tuned properly. I can't say that it is as good as factory. For top end it is great, you just need someone to spend the time to tune it properly for cold start idle etc. At the moment I still need to get the cold start tweaked, but aside from that it is cool. Other benefits of the EMS over PFC is the fact that you don't need the car to keep all factory or close to factory sensors, like AFM's (I still have mine on there but it isn't doing anything), plenum idle sensors, etc. I looked at a PFC but with the custom plenum and XF throttle body it was too much stuffing around. Also the amount of other options with the EMS is mind blowing.
Macka. I got the Trust bonnet from Bodyform motorsports in Sydney but it was for a GTR and I had to do ALOT of modifying to make it fit. The GTR bonnet, believe it or not, is 20mm longer than the GTSt's. The mounting brackets had to be moved as well as heavily modifying the bracing underneath so the thing would close! It still is no quite right yet as it sits flush top and bottom with the gaurds but it sits high in the middle.
Jeff.
MFX - just saw your hilux - nice interior.
Where did u get it retrimmed?? and how much would it actually have cost if you had to pay. My hilux has recaro interior and im thinking of retrimming them in leather and suede. Got any numbers I can call to find out costs?
thanks
Dave.
p.s - what did you use on the dash? has it been painted, or covered in leather.. or something else?
thanks. mfx's dash looks so nice. I gotta find out how he got it looking so clean...
currently my 4wd has:
single battery
k&n cold air intake where 2nd battery used to be
turbo smart boost controller (12psi)
autometer boost gauge
tinted (got that done yesterday)
and over the next month i am installing a stock r33 intercooler as a topmount where the old airbox used to be..
i am hoping for around 60+ kw at the wheels :cool:! but hey, they are 45kw standard so a 20kw increase would be good.
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
