I have a 5 minute old N1 Water pump for R33 -34 GTR for sale. Asking $260 including postage to anywhere in Aus
I incorrectly bought this brand new last week for $340 and fitted it to my R32GTR to find that it doesn't seal correctly. I have just rang nissan and have been told there is a slight differance for an R32GTR water pump and this pump will only fit a r33 - 34 gtr hence why it wouldn't seal properly. I rang the car on the host for 5 min with the water pump on, that's it. Still brand new! Have reciepts ect.
https://www.sau.com.au/forums/topic/167946-n1-water-pump/
Here are some photos:
https://www.sau.com.au/forums/topic/167946-n1-water-pump/#findComment-3113414
whats the difference?
i was always under the impression that all RB water pumps were the same. hence why i want to run a N1 pump on my RB30/26dett
Premo,
There is an elongated bolt hole in the N1 water pump which seals correctly on R33-R34GTRs but for a 32 and probably rb30 you need to tig weld the hole up and re-drill the correct size. Otherwise it leaks from here. Other than that is identical.
https://www.sau.com.au/forums/topic/167946-n1-water-pump/#findComment-3119973
  • 3 weeks later...
hi mate sorry to chat in your thread but weld it up and it will work fine - AFAIK there are no r32 n1 water pumps - better check nissan didnt give you a standard 32 one instead
https://www.sau.com.au/forums/topic/167946-n1-water-pump/#findComment-3157106
Duncan,
I've since done the research and found out exactly the same thing. It is a genuine N1 pump and requires the elongated hole to be welded up. I had already purchased a new standard pump and fitted it SO IT'S STILL UP FOR SALE if someone wants it!!! I couldn't be stuffed changing my pump again.
https://www.sau.com.au/forums/topic/167946-n1-water-pump/#findComment-3160871
Duncan,
Where is the hole which needs welding? how much u selling it for?
https://www.sau.com.au/forums/topic/167946-n1-water-pump/#findComment-3162232
Price is $240 posted as above.
Have a look at the photos on this post, there is one long hole close to the impeller, this needs to be filled in with a welder and redrilled to a 6mm bolt only on a 32gtr though. It will seal on a 33 and 34 as is.
https://www.sau.com.au/forums/topic/167946-n1-water-pump/#findComment-3167238
use some liquid metal putty to fill the hole (allow room for the bolt though), done it on mine and had no issues and plenty of others have done it. saves welding it and distorting the flange surface if it gets too hot. about a 5 min and $10 job to do it :)
https://www.sau.com.au/forums/topic/167946-n1-water-pump/#findComment-3170507
