okay while my 25-30 is being rebuild i thought it would be a good idea to put in a custom sump, with baffles, and a larger volume.
i can send it into adelaide and they modify it with a hi-energy sump but its 700bux. i wanted to make my own.
anyone have detailed pics of what theirs looks like or any advice in general would be greatly appreciated
thanx
  • Replies 59
nice sump mate, good to see rb30 in the states (dont forget to tell eveyone where the block cam from :D
got any pics of the baffles also.
the rb26 sump would need an extra mod to rid the front shafts- so thats one reason not to.
what sorta baffles do they have inside??
also wouldnt the stroke of the 30 hit the standard baffles on the sump??
Funny someone should mention this as im in the process of fabricating an ally dry sump pan at the moment. Different to a normal gated sump with extra capacity, just a very shallow pan with a few valleys for the two pickups for the pump. When i get closer to finishing it ill get a few shots of it and pop em up. At the moment ive only got the flange cut out, and other peoples paying jobs come first unfortunately. If only there were more hours in the day :D
Not sure about the stroke, someone will know that
Yeah, its no big drama to remove the front diff.
Mine was done in that manner.
When 350-400rwkw GTRs run around here in melb with the stock sump on semi's...
That kinda tells me the stock sump works quite well and would be good for 99% of setups out there
Im with Nismoid. Why bother with a big dollar or even custom sump when the OEM item with the diff removed and baffles fitted with sufice perfectly.
If you fit an oil cooler you have increased the volume slightly and honestly if your going all out ditch the sump and use a dry set-up straight up.
Greg's S15 with the RB26 fitted runs a factory sump and has no issues whats so ever and Id garantee it takes a lot more circuit abuse than 90% of the other cars getting around.
From cubes DOHC guide: Grind off the RB20/25/26 fins towards the back of the sump, the rb30 crank and rods have a longer throw and will foul. The RB30 sump has no clearance issues in the R32/33 Skylines.
My car has the standard RB26 sump with a tomei sump baffle in it and no issues to date what so ever with oil pickup.
Have included some random pics I have on my computer of a custom sump for an RB, I like the design of this one....
Dave you have any form of aftermarket sump baffles fitted???
We run tomei baffles in all of out RB26's and never have any problem with surging. Ive got guage in my GTR and after 100's of wakfield laps, oran park and eastern creek laps Ive not once seen a fluctuation in oil pressure.
I usualy over fill by a litre anyways but only because the thing still leaks out the crank seal when it gets really hot.
    • Nah it factory manual not sure about ratio but it looks like there’s been some work at the rear
    • so I need a new speedo cable
    • Throwing my spoon to the soup here a bit.  When I installed a 044 back in 2012, along with the direct power mod, the car became very difficult to start. To a point I burned one starter motor as I was late for work and tried to get the thing going. With some tuning and careful use of gas pedal when cranking it became bearable. Trying to make this short as possible, but the 044 died after 2-3 years, after which I went with an AEM 320lph pump, which also died after about 4 years to my dismay. After that I went with a Nismo pump, and while trying diagnose an emissions problem, I noticed for the first time that my fuel pressure was 5bar/72psi on idle, and that removing the vacuum line did nothing. After monitoring the situation, and removing the direct power feed and going back to FPCM in attempts to remedy it, I noticed there was fuel in the pressure regulator vac line. Kept the FPCM, installed AEM external regu and the car became sooo much better in every way, including starting. And I had driven it like it was for 11 years.. Anyway, I agree these are likely two different problems, and the FP problem you just haven't noticed before. I do not know much about haltecs, but what first came to mind was the CAS, which probably is not there any more. So how is the wiring from haltec to gauge cluster? How is the battery voltage and alternator?
    • Your car was auto before? You have different diff ratio (auto vs manual i think? or n/a and turbo?)
    • +1 for getting a screen off alibaba, CarPlay/Android Auto is vastly better than whatever navigation cars had 10 years ago. I got an Android screen for my 2015 BMW, huge difference. Fully compatible with factory stuff including iDrive controls.
