Old dyno before cams and exhurst and only 15psi.
New on with cams and exhurst and 18psi.
I am running HKS 2530s as title
Boost controler is Blitz ID3
Cam dial in no clue thats up to Dart automotive the tuner.
They never said it couldnt be done they just said it was alot of money for small gain pulling the turbos out.
Anyway man problem now is that car is maybe a bit too loud with the new exhurst. Dumps are not fitted are just sitting on my desk will be done later down the track or may sell the HKS exhurst and get something thats not so loud.
I thought you could buy them muffler tip inserts for them exhausts? Not sure now. Just plugs in the back and reduces the sound down and you can take it back out when you want it non restricted!
Anyone got any more info on this or if it's my imadgination :) i'll have a look!
  • Replies 48
It has the tip inserts even with them in it was loudish got defected yesterday for the exhurst being too loud and low, so will have to do a Db test now to see how loud it is.
Then on the way home i blew some gasket on the plenum side i think dam car is cursed
Power is in Awd, would most likey make 350 odd kws with boost on 25psi anyway now i need to clear my defects and fix what ever that problem is.
Can anyone comment on the need with the trust/greddy dump front pipes (pictured above) to brace the pipes I think to the bellhousing
am sure I read on here somewhere that without bacing them it can cause drama's with cracking pipes etc
(from memory the pics on that thread were no longer working)
Am hoping to fit these to mine soon but using garret turbos, supposedly that makes the job harder than using trust turbos as well
Should be alot a fun but hopefully worth the effort.
You should brace any exhaust as best you can really.
When things get super hot, you dont need weighted items dragging down other parts
They will warp/blow gaskets etc etc. All sorts of annoying stuff :)
Hmm they are rather nice might look into getting a set in to try on my GTR.
There certainly are a few neat little tricks to getting the turbo's on an off quickly. But once everything is removed from around the area its really not hat hard.
Angus smart which GTR is yours?? we see so many of them its next to impossible to keep track of them atm.
Dark blue one from the car club :)
Then on the way home i blew so gasket on the plenum side i think dam car is cursed
Good luck
They will warp/blow gaskets etc etc. All sorts of annoying stuff :whistling:
Cheers mate figured as much will have to try an find that thread an see if anyone has some pics of how they braced theres
hopefully will be reasonably obvious anyway
they are braced at the gearbox mount which is more than adequate (never had a return in 6 years). The main reason for cracking pipes is a lack of flex joints on the cheap ones. A good GTR front pipe will be equal length and have a flex joint in one of the up pipes.
Edited by URAS
cheers URAS yeh mine has a flex joint in it so I dont need to add additional bracing yes?? hope so want to heat wrap the dumps so will be easier without extra braces added and in the way.
Will wait till they arrive an have a good look might even ceramic coat em not 100% sure yet.
    • Nah, you failed to pay your washer cover subscription and BMW have revoked your access.
    • Haha thanks Lith,  So it's currently working quite well and the torque reduction is setup and working phenomenal. It also got a custom torque convertor from All Fast in WA. Stall speed somewhere around 5500rpm unlocked but still with the lockup. The car went back onto the dyno after a 3yr hiatus (even with the dbw, and other mods completed in this time) managed to make ~515kw at all 4 hubs. Sean setup the Torque reduction which now sounds awesome and working well. We setup adjustable torque controlled launch control aswell.  Man what a feature. Especially when drag racing on street tyres I Managed to get out to the drags late last year and tick a huge bucket list item off of running mine and the cars first 9. Car went a 9.98 @142 Still had the young fellas car seat in the back aswell.  This was on 255/40/17 Nankang AR-1.  Currently the Turbolamik is still completing it's own torque calcs and managing shift times from there. Unfortunately emtrons can export is still a little restrictive to export the ecu calculated torque just yet but I have recently been suggested a work around that I just haven't had a chance to trial yet.
    • Yeah its bad eh. Ey! Watch your mouth. Yep, spot on. The rear's are always gone too though from brake checking. I had them perilously close to a tree that we had taken down. I think the tree peeps may have taken it. Either for a trophy, or accidentally.
    • f**kin' yikes! That insulation is the shittest stuff I have ever seen. You need to do an insurance job on that f**ker, pronto. WRT to the washer cover, I would have said that there'd have to be some at a wrecker, then remembered that it's a BMW, and reasoned that every single wrecked one would have been tailgating and so the front end would be trashed.
