Hey guys,
Looking at buying a HKS TO4E, was wondering if that is a good responsive turbo for an RB25. I heard a history of lag and bodgy response from these turbos? Are these direct bolt ons, i am aware that you need oil n coolant lines but do u have to change intake pipe, dump pipe etc.
thanks
john
http://www.hksusa.com/categories/more.asp?id=1094
https://www.sau.com.au/forums/topic/167968-hks-to4e-for-rb25/
Dont.
There are much better turbos out there.
HKS GTRS, 2835 or from the garrett catalogue 3071 IW or 3076IW.
These are all modern turbos that will fit your stock manifold and outperform your stock fuel system. 3 need a custom dump pipe and lines, the gtrs will fit the stock dump flange
For $1000 u cant go wrong. I have most of supportin mods like big injectors, pump, fmic, full xhuast but standard internal.
These also come with oil n coolant lines so its a good deal. Dump pipe wont cost me more than $250, though shouldnt it bolt straight to my rb25 t3 manifold.
cheers
john
Dont.
It's your money, but i could think of a few other things i'd have with 1k.
Just confirm that it's internal gate.
I'd be inclined to spend the (roughly) 1700 on the 3071 or 3076 myself but, like i said, It's your money.
You asked for opinion, and then for 1k you say you cant go wrong?
Sounds like your mind is already made up >_<
But im with BHDave. Waste of money, there are far better options out there that dont even cost much more.
Get a hi-flow if you want response. The t04e at a rough stab isnt going to be on till 4500rpm and even then peak power will be average compared to something that is actually using current designs
I had a Garrett t04e, simply put it was shithouse.
The GT30 Garrett i stuck on there after was better in every way possible.
i thought a to4e would be responsive cause its smiilar design to t3/t4 highflow? i will end up spend 1400 for this new turbo put it costs 1700 plus just for the turbo alone if 3071 or 3076 etc etc- lookin at 2600 including modifcations to support and fabricaiton.
the turbo t04e has been rebuilt by ATS, however its a HKS compressor.
thanks
john
If similar in design you mean they both use 1970's technology, then yeah. They are similar in design.
How is a GT30x going to cost 2600 including mods? The turbo costs 1700 and its a bolt on affair.
Either way, its your money dude. Two people now have told you it wont be anything special.
And thats just how it is if you like it or not.
That HKS spec T04E is not a T3/T04E hybrid its a full "T04E" meaning it's got a heavy T4 turbine and in its smallest trim size - 62T AKA "N" trim . Its compressor is 57 trim which is not real small either . Any full T04E turbo is going to be big/heavy/not very responsive .
Also a lot od misinformation on what a "T3/T04E" really is . When built in America they use the TB31 turbine (NOT some ancient small series T3 turbine from Nissans RB30/FJ20/280ZXT/Z18 ) . The TB31 turbines are ~ 64mm OD not 59mm like our early Nissan/Garrett T3 turbines . If you used the TB31 turbine with a med trim T04E turbine ie 50 trim they can work reasonably well . Garrett actually make turbos called from memory TA34's and they do work , I seem to remember posting picks on this board of the "TA34-1" so do a search on that . It runs a .58 A/R turbine housing in T3 flange and the word is they work reasonably well depending on your expectations . I did see one at Turbologic (Port Kembla) and Fred did say the RB20 people thought they were a good cheap upgrade though that was a few years back .
I wouldn't throw HKS dollars at a T04E when there's noting you can't have built in them . Cheers A .
    • How f**ked am i? what would happen if i leave the magnet inside there?
    • I'll update you guys when i get home from work, im going to try to fish it out.  I just realized that i can't even drop the oil pan. The whole front diff and axles are connected to the oil pan... is it even possible to drop the oil pan without taking out the motor?
    • So recently at the track had experienced a loss of throttle after a period of WOT after installing the emtron ecu, recently did some logging to troubleshoot the issue and found the ECU was cutting due to a low oil pressure issue. Going over the log can see that while accelerating at 4k rpm will see 100 PSI of pressure and holding steady at that level until getting off the throttle which then after can see as low as 25 PSI at 3-4k rpm and will recover back to a normal level after that.   Wondering if anyone has an idea what could be the cause as it just feels abit strange and i dont feel like it could be a sensor issues just due to it clearly sitting at a good pressure until off throttle, in the attached can see a 3rd and 4th gear pull but can even perform great through 3 and 4 gears of WOT but still once off throttle and getting back on it will see pressure drop.
    • There are a few different ways of doing it. I'm currently running two 1000cc pre-TB nozzles and PWM the pump for control. I'll be moving over to a constant pressure system and direct port. I'll run the pump off a regular relay, have it cycle on roughly 5psi before I start injecting to build pressure and then PWM a WMI solenoid (It's basically an injector that can take a lot of pressure and not corrode with water and meth.) The solenoid feeds the 6 direct port ~200cc nozzles. I'll also keep one ~250cc pre-TB nozzle to help keep IAT's in check.  Safety will be a little different as well. I used to use a pressure switch but will be moving over to a pressure sensor between my solenoid and nozzles. I'll trigger my solenoid and if I don't see specific pressure within a specific timeframe (e.g 100psi within a second, 175psi within 2 seconds), I kill it and revert back to non WMI maps the same way I did it before with 4D in Haltech. I was just figuring out the timers in my ecu last night. They made that a little more complicated than I would have liked... I wish Haltech offered a larger set of logic/math functions like other ecu's do. I can't do very much with just AND's and OR's.  I've been asked to do fuel/ignition mapping on a medium bore engine at work in May (192L V16). Being the only programmer in my region and having went and opened my mouth about knowing the ins and outs of fuel/ignition mapping, I have now been deemed an expert. Fun fun. The entirety of the logic and algorithms are programmed in C on a PLC. As I spend more time figuring it all out, I like what I see and eventually I may consider doing the same as a pet project to replace my ecu.
    • This would be interesting, would you feed it via a 2nd row of injectors? Or just usual WMI nozzles?
