now what are steps involved in making ur engine bay a lil more dressier
e.g silcone hoses , braided lines, powder coating ( what is this )
is dere anybody dat professionally can do it for u without me pulling a hose dat i dunno what it is for?
apart from that any advice is good
cheers
https://www.sau.com.au/forums/topic/167996-engine-detailing/
rocker covers diy, coil pack cover diy. search and there are many threads relating to how its done. also you can do timing belt cover yourself.
dressing up other things is up to you. powder coating is similar to painting just the layer is thicker and if done corrctly is very effective in high temp projects. things i would recommened powder coating are the plenum, all your fmic pipes, and thats about it. you can buy coloured radiator hose kits from auto bahn, and other hoses u can just measure diametre and replace hose for hose once you purchase the desired colour hose.
professionally will cost you heaps. diy and save some cash
things i would recommened powder coating are the plenum, all your fmic pipes...
Can I ask why you'd recommend powder coating ic piping?
Would that have a negative effect in regards to cooling performance by effectively creating a layer of insulation, and inhibiting heat from dissipating?
i tried searching it... rocket covers " engine detail
ENGINE
stuff like that
ahh is see who usually does the powder coating on these forums? thats well known for em
is there way i can tell which lines are water, oil etc so i dun replace a silcone hose with a oil isntead using a braidedline etc
... there's no rockets in the engine, so the term "rocket cover" probably wouldn't return too many results. :P
Have a look through some of these for more info.
http://www.skylinesaustralia.com/forums/in...howtopic=107788
http://www.skylinesaustralia.com/forums/in...howtopic=161128
http://www.skylinesaustralia.com/forums/in...howtopic=150105
http://www.skylinesaustralia.com/forums/in...howtopic=157397
Hey guys got an r33- gts-t i wana get my pipe lookn from factory to stainless steel is dat possible
what is involved ?
what tools and n product o i need to get it that look from factory n not spend money on piping instead doing it myself and polishing it to look stanless steel is it possible
its worth powder coating the pipe that comes from the front mount to the plenumm, it insulates the pipe and keeps the cold air that has just passed through the fmic colder than allowing it to absorb heat on its return back into the bay.
yer i thought of that but i wana get the engine like stainless steel look and make it look clean wit new silicone joints and so on
so wot polsishing product u recommend and what tools do i need to do it?
um, polishing product? y just get it powder coated in a chrome. no polishing and fuss. just a wipe occassionally. tools to pull apart an r33 bay is simple, 2 screwdrivers, socket set and spanner set. done. oh and some side cutters and pliers.
btw powder coating in a chrome is cheap, i had 4 wheels powder coated in gloss white for $80, so some piping in chrome wont be more than that.
Edited by cheez
ahh i see that means its better off for guys to have the rocket cover, and there pipes polishe by powder coating them with chrome
that is a desired effect amongst most ppl
im interested n your shop for dahtone racing
im sure if you post here what you can help us with an stuff that ppl in sydney will surely come around to ya.
thats some nice engine bay work there.
hey russo im not sure what material your intercooler pipe is but try steel wool an some multigrease wash to clean it first.. it shu become shiny.. ( if its not chrome ) then shine with brasso.. and after that just lacquer it with high gloss so when ust n shit hits you can just wipe it off?
thats what oldman across the road told me
n its working so far
cheers bois for all ur replies
you cant powder coat chrome its like trying to paint chrome
it never comes out the same
to chrome something u need to polish it to a mirror like finish then plate it.
polished metal IMO sucks because theres so much maintenance, it goes dull very quickly.
with regards to Dahtone Racing we are a mobile service so we come to you
yeah but then what you polished and plated the parts in your pictures so well
i dun think i've seen a car that looks that darn good in the engine bay
i wanna get da chrommmee !!!!!!!!!!!
lol mite cause like a grand or sumfin ahahhaa
everything in mine is chromed except for the wastegate, brake master cylinder and clutch master cylinder
i ran out of time to get em done for the show, but they are getting moved up under the dash anyway so they wont be seen at all
if you want parts chromed PM me i can give you prices
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
