Can someone decipher this wiring diagram for me.. Was running through it with Abobob, just want to make sure :P
It's for the Autogauge Temperature Gauges
So from what i can tell.. Red needs a 12V+ constant source..
Orange needs a lighting power source for dimmer function, e.g. cigarette lighter light power?..
C wire, taps into an ignition power source - cigarette power?
A,Black and Black on the sensor are all ground, does this look correct to people, can someone please confirm..
Also - quick update.. I managed to take out the fold down DIN tray last night, i've found the grommet I need to feed everything through, just waiting on a sunny day to do it.. bought some scotchclip things so I don't have to solder the wires. Will post photos as/when i'm done :/
Cheers
Links
red is always 12v*, so your good there
the orange with a white stripe is your illum wire, makes it light up with your headlights, grab it from your stereo or lighter ifits there
C wire is most likely your accesories wire, grab that from your stereo
and black is most likely ground yes
:3some:
really the correct thing to do is to run all new lines to the fuse box... but i know you wont do that :worship: so steal shit from where your headunit is mounted and what not...
well, borrow is a more correct term...
*Disclaimer: ive seen some f**ked up shit... but most likely its positive :banana:
More like splitting the wire as opposed to "Borrow" :banana:
Dont forget to use HEAT SHRINK!!! Lovvvve that stuff! :worship:
Links: Guess your getting your car ready for BEST Interior at the shown shine with all these guages? lol :3some:
My guage install pics if you havent seen em: http://members.iinet.net.au/~doodz/car/din_guage/Done/
Hahaha, Doodz, your on the money, i'm gonna win the stock with interior bling award :cheers:..
Thanks Steven, don't think i'll wire it to the fuse box (no-one else seems to).. Looks like I was on the money, cheers for that, just need a free weekend to do it now..
Ok, so I got around to wiring up the gauges today.. Managed to get the vacuum hose through the firewall via the coat hanger method...
Got a ground up and running, it does appear that my cigarette lighter's 12v wire is not working properly :) I had power for about 2 secs using my multimeter on it, than it went to 0, is there a fuse for the lighter??
So next I wired it up, but got a constant 12v wire so even when it was off I had power to the gauge :P oops.. So tomorrow i'll have to hunt for a new wire that I can piggy back or run a new one from the ignition..
Also - did anyone have any issues with the justjap din holder for the gauges?
I just got these gauges, the wiring in my 32 was pretty simple.
Green wire goes to the sender.
If you want the gauges to light up white all the time (with or without the headlights on), wire the red and the white to an ignition wire. Red and orange to ign if you want amber all the time.
If you want it white during the day and amber at night, wire the red and white to ign and the orange to your headlight switch.
Vice versa if you want amber during the day and white at night (swap white and orange around).
just put a test lamp to a wire with ign off, then turn ign on and see if it lights up, then theres your wire.
Theres one that should go to the headunit, usually red as well. If you have a turbo timer, the power wire to that would do nicely. Or if you're really desperate, find the power windows power wire.
I grounded mine to the cigarette lighter
The warnings are preset.
Let me know how you go with your oil pressure one, i seem to be having problems with mine.
When the engine is revving, the gauge seems to work, but once it's idling, it drops to 0.
Ive got another sender to put in but i havent gotten around to that just yet.
I had to cut a few bits of my dash out and move the aircon controls to get the DIN plate to fit.
Edit: Just re-read that you don't have an oil pressure one....
Edited by r32woohoo
    • That's the thing. Especially at idle, changing the cam angle by that much could be spewing more fuel out the exhaust courtesy of everything happening that bit later. More fuel also means more air (if the fuel didn't burn, then neither did the O2) and so the O2 sensors can start to tell interesting but misleading stories. And the specifics of what is happening could easily be affected by everything else you changed as well. And it could be dynamic, where a few revs more or less could somewhat change how the engine is breathing.
    • Good idea on the temp probe. The mv readings of the O2 sensors are very similar to one another, as is the injector pw. I went through logs in the past to see if there was a discrepancy and there is. Because they alternate up and down as narrowbands do.. they do often 'switch' as to which one is more. They were never 20%+ (more like 1-2%) so it's possible the difference between 20 and 15-17% is a similar discrepancy to 2.0% and 1.7% which I wouldn't have really noticed in the past. We did think about spacing the strut brace. Unfortunately the ~20mm that the GTR brace is lower than the GTT brace is effectively what you need to clear the vents. Moving it up would make it very uncomfortable, but it's plausible that 10mm is a unhappy medium between both hard places... The good news is.. using MR HAMMER it was actually pretty easy to bend back the bent bits to make sure the guard and headlight/new headlight tabs line up right. Yes, we used a R34 GTR guard to make sure the bolt holes all lined up with a known straight guard. As above, you can see the side skirt and the GTR guard are not meant to play together, but everyone seems to think this is a simple fix to the point where nobody who has had these talk to one another mentions how... ...so I'll just assume they know how to fix it when it comes to paint jail time again. Whoever they are. Nobody returns my calls. There's so much changed with regard to the ECU and the car.. that the next step really is to connect the scanner and attempt to drive the thing. It'll be pretty clear pretty fast how in or out everything actually is...
    • That's nasty! I think there is perhaps an inherent problem is using elastomers in such environments. The whole thing can and will get quite hot, and elastomers are not famous for their temperature resistance. On top of that, if the components are cast rubber or urethane and so on, there might be QA/QC problems with bubbles or voids in the material that could critically change their performance. They might just tear apart after being squished (presuming that any elastomers are used in compression rather than tension, I'm thinking that you squeeze one with a void in it and it tears the wall of the void to the outer edge of block, then the next time it extends or otherwise twists, it just gives up). This is all purely hypothetical, but it makes me wonder if the things that they have put into it to make it nice to use/live with are perhaps going to cause occasional failures like this. I wouldn't be getting up in arms over it, unless there are many repeats. I have personally ruined an Xtreme clutch - just an HD thing. I can't remember if it was still behind the 20 or was after the 25 went in. But it inverted some of the retaining spring/clip things around the outside. No-one could explain it. It wasn't thrashed, there wasn't heaps of torque being put through it, and there were no obvious problems other than the above. They were quite concerned by the event so they replaced it even though it was a few years old, which was very nice of them. As far as I am concerned, these things happen with clutches.
    • Any damage to the box/input shaft?
    • Hey there Mate , I just got my local guy to install it Waterhouse Performance, Penrith (specialise Nissan/Datsun and other performance cars) , you can do it yourself if you like , AMS has instructions on their website.  Cheers Pac
