be using the 180 for drift. and its going to be a 180 rolling shell so yeah
The RB20 would be perfect if you wanted to push your centre of gravity forward, encounter packaging issues fitting bigger heat exchangers, as well as increasing the car's total weight, while having less midrange torque.
https://www.sau.com.au/forums/topic/168043-rb20-in-180sx/#findComment-3110021
If you can afford an RB25DET I'd suggest it.
You can set the car's suspension up, to a certain extent, around the extra nose heaviness from the bigger engine and if its drift-only then making major changes to the front end to fit all your coolers isn't an issue.
The SR20 will make more midrange torque than an RB20 (while probably having just as much top-end) but there's no replacement for displacement.
https://www.sau.com.au/forums/topic/168043-rb20-in-180sx/#findComment-3110083
Umm... If you have an R32... Wouldnt it be more logical to put an RB25 in to that, and sell the RB20 to someone who wants to waste their time putting it in to something it shouldnt be in. ie a 180.
Just a thought.
https://www.sau.com.au/forums/topic/168043-rb20-in-180sx/#findComment-3112913
RB25's are god, RB20's are shit.
sorry, dont mind me, im just trying to fit in here on SAU.
hehehe thats so true (the 2nd part)
I know a bloke with a stock rb20 in a s14 (had a CA previously) and it's alot quicker than another friends standard sr20 powered 180... but then the cars lighter i guess
Edited by r32 gts-turbo
https://www.sau.com.au/forums/topic/168043-rb20-in-180sx/#findComment-3120565
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
    • @Duncan Random side note, did the cops give you the driver/owners details of the taxi and then did Shannons give you a refund of the excess once you supplied those details?
    • Yeah to be clear I'm not naive, I'm sure all insurance companies are a bunch of arseholes who pay people bonusses based on the value of genuine claims they avoid....I just don't want to go back to one that has personally f**ked me multiple times in the past
