Just a quote from www.popularmechanics.com , just incase you don't believe me.
(Battery) Charge
With the battery charged, open circuit voltage should be 12.6 to 12.8 volts with the engine off and all loads off. With the car running and all loads off, the voltage should be between 13.6 and 14.5 volts.
The only other thing is where you tested the voltage. Could be the terminal clamps are loose or the leads are not conducting enough current.
If it is the starter motor, try giving it a tap with a hammer or metal pole, but it sounds to me that it is trying to turn over.
https://www.sau.com.au/forums/topic/168052-car-wont-crank/#findComment-3109387
Yah! I think its the battery too. It happened last year during the winter the same thing. I did not take note of it as I thought its OK. But now, i think i have to replace the battery. Anyone know where to get one? I have read somewhere that the battery must be a "dry" type as it is place in the rear boot. Hmmmm.......must be expensive!!!!
https://www.sau.com.au/forums/topic/168052-car-wont-crank/#findComment-3109486
theres a place in queanbeyan which sells batteries wholesale, good price and the guy knows batteries, he spent about 10 minutes explaining why i needed a certain battery for my car :domokun:. Just tell him the make and model and he will go hunting through his warehouse. Can't think of the name but its on Uriara Rd near the roundabout just after the petrol station.
https://www.sau.com.au/forums/topic/168052-car-wont-crank/#findComment-3109534
    • Update for the sake of closure   Ended up getting the intercooler piping all sorted, new plugs and yellow jacket coils, and she was idling mint until it warmed up while I was bleeding the cooling system. Found the misfire to be localised to cyl 3 by unplugging coilpacks, ran a compression test, that checked out, then decided to get a mate to check if that spark plug was firing out of the motor. Upon cranking it over, with the injectors disconnected, the car actually fired and ran on a couple cylinders and heaps of fuel came out the top of cyl 3 I'd say that injector's either spraying incorrectly or spraying far too much, which is fine as I'm planning on replacing them anyway I'm planning on making about 250kW on flex fuel, and have a set of 1000cc injectors from ozautosport, obviously overkill but I'm planning on building the motor and running more boost further down the line, do you reckon they'd be too big for a smooth idle on 98? Thanks for the replies gents, much appreciated
    • I'm confused. You said you want to "remove the clear coat from most panels" but it sounds like you are actually doing a full respray? Few random things to add -  If you chase the blistered paint with 120 grit, I can almost guarantee you'll chase it down to bare metal (that's fine). But if you paint the car from here, you'll have nice little indents where ever the blistered paint was. The new paint won't magically level out the low areas, you need to fill them. Which leads me to the main point I wanted to add, make sure the whole car is flat before you paint it. All those areas with blistered paint you sanded out, make sure to fill them and triple check they are flat with a block guide coat. I'd also check the whole car is flat with a large block and guide coat but yeah up to you if you want to go that far.
    • 300hp (225kw) is barely outside the standard turbo's range with a bit of extra boost in it (200ish). If you are going to change the turbo you should aim for 250-300kw (330-400hp) to make the expense worthwhile
    • A couple of things, firstly omg that turbo is expensive! $3,000 USD for dinosaur technology is robbery. You could buy a G series turbo and have a good amount of change instead.  If you want a good budget option, have a look here - https://hypergearturbos.com/product/rb25dethighflow/ If you are keen to spend more, have look at the modern turbos, Garrett G series, Borgwarner EFR, etc. Have a look at the RB25 dyno results thread for inspiration.  If you upgrade your turbo to something that will support the 300hp you want and only "probably" have Haltech ECU, your car will only "probably" run. Actually, no it won't run. You are going to need the ECU and injectors at the time you do the turbo upgrade.  No thoughts on "this much boost" as you didn't say how much boost that actually is. Having said that, plenty of unopened RB25's making even more power then what you are chasing.
