I have an R33 GTS-T 4door ('94), and just recently when I start my car there is a noise coming from the dash or somewhere in that general area that sounds like a pulsing beat. It sounds as if something is trying to move or open and is getting stuck or held back by something. Kind of like the sound a pedestal fan makes when you try and stop it from oscillating. My friend, who dyno tunes ands works on alot of Skylines says its a common problem with them but he is not sure what it is.
Please help. If anyone knows what it is and how to fix it please let me know.
:thumbsup:
when i reset my ecu (disconnect the battery) and then re connect. after a drive or when i start it up, it makes a ticking king of noise. sounds like someones on a typewriter.. i assume its just the ecu , but i dunno if your in the same boat. it goes away after 2 or 3 drives . i.e happens less and less
Nah this noise happens almost everytime i start the car and only lasts for 10-20 seconds then stops. I've been told that it may be a problem with the aircon unit. See link below:
http://www.skylinesaustralia.com/forums/in...howtopic=168054
I know what you mean. It sounds like a windscreen wiper motor going back and forth twice. Very faint though can hardly hear it.
thought it was just my car hehehe
I wouldn't mind knowing what that sound is too, it comes from inside the dash
One of the motors for the air vents perhaps... could be catching on something or broken. Just try'n pin point where exactly the noise is coming from, if it's behind the plastics dash facia thing pull it apart and have a look. There's DIY how to pull dash apart if needed, it's fairly easy to do though.
Its something to do with the fans from memory.
There is a post on here somewhere as well as a how to fix it tutorial. Not really worth fixing though. Its a whole dash out job.
It causes no damage anyway.
that my friends is the motor that directs the air flow for the aircon/heater system. its a little servo and over time the gears wear down and they start to slip. when i bought my r33 it was making the same noise and the dealer i bought it off fixed it before i picked it up. massive job, whole dash and aircon system needs to come out as its right down near the firewall on the inside of the car. good luck with that one...
its the charming noise of 33 owners, very common, something to do with climate control unit, which i ve heard people have replaced and they go again in 6 months or so.. try moving the direction of air on different settings every time you start it and see where is happy meduim is.. i use to vent my on fresh air both face and leg postion and it didnt make a sound, though on other postions knocked persistenlty..you got to love it hey
I find there are two noises. There is the noise that is the climate control. The best way to reduce this noise I found was to turn the fan speed up to full for a bit then turn it back down again and the noise seems to be a lot less noticable.
The other pulsing noise that I think JodieR33Chick is refering to actually comes from behind the dash. My car made that noise for a few weeks after I got my car. Then it mysteriously went away and only comes back very occaisionally. I thought it may have to do with the dramatic change in climate from Japan to Australia (I'm first Aussie owner) and that it was something behind the dash expanding in the heat. It may sound stupid but I don't know how else to explain the pulsing noise as it seems to be so inconsistent.
i also sometimes come across that problem...it definately has something to do with the aircon unit....it sounds like the motor is sliping or someting weird is going on....best thing to do is to play around with the settings and it just might go away....i have my airflow at the leg and sometimes when i do switch it to face it makes the ticking noise but only when i turn the car off and on again....so best in my situation was have it pointing to the leg....u most likely have to play aroung and hopefully it goes away for you....best of luck
yeh mine only happens when i start the car up, even if i dont have the aircon or anything on, just thumps for about 4 seconds and thats it, never happens again until i start the car again\strange.
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
