Hello guys
Spent last night trying to bleed the clutch for AGES. It's an early R32GTR with a push clutch.
The best that we could do (sure I am useless by this is with Troy - ylwgtr2 - who knows what he's doing) was to get the pedal to firm up at the bottom 1/4 of the stroke.
The link adjustment in the pedal area are right.
We pulled off and disassembled the master and slave cylinders - the bores all look good, as do the seals. As far as we could we bench tested the cylinders and they both hold good (air) pressure.
What we end up with is the bottom 1/4 of stroke actioning a very small amount of the slave - and with fark all force pushing the pin.
Funny that when we block off the banjo we get a firmer pedal throughout… which leads me to believe it is
1. a farked slave
2. air in the system
However, our testing shows the slave should be OK, and we bled SO MUCH fluid it's not funny. We're talking 1.5L for just the clutch…
Also, cannot be the lines, as there is no leak anywhere. Lines just hold pressure, and are in excellent condition.
New Ogura Racing Twin clutch installed. Note that it will not be the clutch that is the issue as we don't have force at the pin to push the fork.
So, questions -
1. has anyone had this issue, and what did you do to fix it?
2. I remember that bleeding the clutch previously was a bastid… is there a order to bleed and what is it? I think we tried every which way
3. why are we getting good pressure at the bottom 1/4 of the stroke?
4. can it be something to do with the actuator that pushes the master from the pedal?? We measured it and it should be contacting the master cylinder piston just fine.
Any help appreciated, though I've ordered a new master and slave ($$$).
cheers
https://www.sau.com.au/forums/topic/168082-cant-get-good-pedal-in-clutch/
a good way to bleed these clutch's is to use the gravity feed.. just make sure the master is full and crack open the slave while the clutch pedal is out and let the fliud drain out of the slave for a while.. maybe one or 2 master cyl's full of fluid.
See if this way bleeds it at all?
If you crack the slave and nothing comes out then bleed the other 2 points before trying again.
have you used the correct pivot ball or installed a thick washer under the stock one to give you more cylinder travel?
or
try bleeding it upside down with a large syringe and a piece of rubber vaccum hose over the slave nipple...this will push all the air out through the resivoir at the top.
and
have you bled the intermediate block as well?
cracked all bleeders every which way. Used the correct new pivot...
haven't tried the syringe method at the slave nipple - will give it a go.
have bled at hte intermediate block too...
It's such a simple but of hydraulics, can't see why it doesn't work!! My money's now on a farked slave...
thanks for all the replies, keep them coming :P
crack the slave and let the fluid flow at least 2 master cyl's worth then close it before it runs out (dont let it ever run out)
atleast spend $70 on a braided clutch line to ease yourself of the pain of bleeding the stock km's of hose/line :D
P.S did you have a twin in it before? if not, how does the height of the surface where the thrust bearing contacts with the pressure plate compare to the old one?
Also, before we go ahead, it was working before you bleed it right? Unless if you've royally busted it when doing the bleed, it shoudl work.
ok, i found something similar when I did a couple clutches last chrissy holidays. I'm guessing that you've got air in your system. Try this please.
put your hand down, and pull your pedal up to the top. press it down again. Then pull it up to the top. do it a couple times, and tell me if it eventually goes back to normal.
You might have stated this, but did you bleed the master cylinder? Ordinarily you need to bleed the master cylinder, THEN bleed the rest of the system. You don't rely on the bleeding at the slave to bleed the whole system.
At last! Someone that got it right!
If you bleed the slave cylidner you can put 50 litres of fluid through there and it will still not clear the air if there is a bubble at the master cylinder. You should be able to clear the air by just 3 pumps for the master and 3 at the slave.
1. Fill the resivour, and pull the pedal up from the floor.
2. attach a hose the the nipple at the master cylinder, loosen the bleed valve and have someone slowly push the pedal to the floor with their HAND, so the motion is slow. Tighten the nipple, and repeat from 1 another 2 times.
3. Do the same but for the slave end, again 3 times.
Pumping the pedal fast will not help you purge the air properly, nor will litres of fluid. Do it right and provided you have the correct throw out for the clutch installed and it worked properly before as Manwhore suggested well you should be operational.
It's got a braided clutch line on it already. Didn't have a twin in it before, but Troy put in the twin so can't comment on the height of the surface where the thrust bearing contacts with the pressure plate...
Manwhore, it was bone dry before we started bleeding it - has been sitting around without fluids for a while. My money is still on the slave - a brand spanker is going on today. Possibly the slave seals have shrunk back a bit and are now leaking.
pumping the pedal - it doesn't go back to normal - you're asking me to do that to see if we still have are in the lines?
cheers
yep thanks we have bled the master first... new slave going on today!
still got air in it.
to save you the obviouse headache. you need to bypass the loop thingy. putting it simply you undo the steel pipe from the master and hook it directly to the clutch hose. (delicate bending reqired)
you will have it done in no time:)
yeah I was bleeding mine and my helper (read knob) let it go dry!!!!!! so mad took me an hour to fix it. those extra pipes are the stupidist things ever invented!!!!!! I ended up getting reverse bleeding it up through the slave then bleeding the master then pushing pedal down clamped off line to slave then pulled pedal off the floor with hand and I heard some air rush out then pdal all good.
I've removed the extra piping now and just run the pipe straight into the flex line. gravity bleed soooo easy.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
