hey guys
after alot stuffing around at courts and suing the dumb c**t how fitted the body kit and painted it,
his not paying up, and i cant be f**ked with anymore,
its a 1989 gtr with a 93 motor which has roughly bout 110,xxx kms (has aftermarket speedo)
after selling this i planning on buying another gtr,
ok the car has every panel pulled off and i will include every part on the bn blister kit if required(no rear guards)
the car will not come with any seats, but can provide seats when i get my new gtr.
the cars is running fine with no miss-fires ect.. i just spent a $1000 getting all the bushes and shit replaced.
except the brake booster is f**ked will provide on sale.
Here is the mods:
carbon firbe bonnet with pins
Pivot speed monitor used to bypass 180km limit
HKS HyperMax coilovers (height and damper adjustable)
18x10 front with 265s tyres and 18x12 rear with 295 tyres
N1 style exhaust (rear muffler is stainless)
Aftermarket front pipes
blitz Pod filters
R32 GTSt steering wheel
FET full auto turbo timer
rear adjustable camber arms
NISMO 260kmh speedo
Front calipers have just been rebuilt, and rotars machined
stuart warner boost gauge
omori oil pressure gauge (not fitted)
hicas lock bar
AVO 100mm cooler
clear head lights and indicators
there maybe a few more thing cant remember
he car is running 15psi and made 222kw
this kit along cost me $4200(BN sports blister kit)
heres a link of what the car use to look like
http://www.skylinesaustralia.com/forums/in...hl=widebody+gtr
im after $15000 with the wheel and 13,500 without,
if you want fast answer ring me on 0420581496
will take pics if there is any intrest, better still come and look at it, located in S/E melb
post-16324-1180843521_thumb.jpgpost-16324-1180843637_thumb.jpg[attachmen
=101526:28052007030.jpg]
post-16324-1180854175_thumb.jpgpost-16324-1180854117_thumb.jpg[attachmen
=101529:03062007038.jpg]
https://www.sau.com.au/forums/topic/168143-gtr-project-car-for-sale/
so what actually happened with the car and the kit?
you pulled it off to turn it into a normal GTR and the pannel shop f**ked up the new body kit and paint?
what is actaully needed to fix on this car beside fitting and painting the bodykit and brake booster
does the current wheels stick out by a mile without the wide body kit?
what happened was the kit got fitted by a dickhead,
couple on months down the track paint started to crack same with the body kit.
i sued the guy who fitted the kit for 18k but his not paying up, so i put a warrant agaist his name so they can start taking his shit to sell at the suction to recover my money. this has been going over a year and im sick and tired of waiting.
so yer the wheels stick out but 2" past the guards and no out work is needed to the car besides the kit, i can start and drive the car with no problems
like i said i will supply every part to make it look like it use to, but the wheels be an extra
also the rear guard will need to be repaired if want pics of the guard ect.. let me no
ok i need a gtr,
is there anyone intrested in trading there stock gtr with mine??
i will include the whole kit, including the wheels
a set off garrett gt2560 turbos with aftermarket dump pipes
and power fc with had controller
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
    • Was that Australia Delivered Duncan? Does it have siren etc?   I used to have remote start on an old 32 two decades ago, it was a cool feature. I used to wake up early in winter for work. Start it and by the time i was out the door a few minutes later the engine was warmed up and the heaters had the car toasty. It was great.    I don’t mine the ambience lighting.  I drive a western star and it has footwell lights and ambient lighting and it’s great! From the pics of seen of them installed in a skyline I think it’s a nice touch
    • re the security system, my Fuga/Q70 has the factory option where the puddle lights in the mirrors turn on when the prox key is detected, it was clearly dealer fitted and has a switch in the lower dash to disable it....it didn't have remote start but TBH I don't really miss that, I had it in the Stagea originally but never used it....we don't often have to warm the car up in the snow before we get in for Australia. And the Fuga also has the illuminated footwells, sounds like a useless feature but I actually quite like the indirect light within the car, it was a nice addition
