hey dudes
i have rb20det
full inch exhast
600x300x76 intercooler + piping
pod filter
gtr fuel pump
ecu (mines chip)
and just installed new rebuilt rb25det turbo (by steve murch, new bearings still the same wheels)
now before i installed the rb25det the original rb20det turbo was boosting 12psi (about 0.9 bar)
i ran the car for the first time tonight with the rb25det turbo on and the cars power feels the same but its only boosting 0.55 bar???
Should i be buying a boost tap and cranking this to 1 bar (14.7psi)?? and getting what this turbo can really achieve?
have i done something wrong?
if i need a boost tap wat would be the cheapest recommendation???
any help would be great thx
If you didn't swap the wastgate actuators over, that could be it.
and your settings were different bi 0.35bar which is right on 5psi
R32 standard actuator is set to 10psi.
R33 standard actuator is set to 5psi (....i think with the R33 boost solenoid tweaking it to 7psi over 4500)
If that the case (which it looks like it is), spend 20mins swaping the old actuator back in :domokun:
spot on the money birnie.
Since he won't have the 2 stage solenoid, with just an r33 actuator, it runs about 4.5 psi. since he's got a few mods like ic, exhaust etc, it'll run a bit more - that's the 5.5 psi.
pop the 32 actuator in and i won't be suprised with your extra mods if you get 11-12 psi. she'll rip really hard.
is it pretty hard to do???
i know how to take pipes off the car and unbolt stuff but do i need to set anything?
cheers
2 bolts to undo on the actuator side, and a 'C' clip on the end where it attatches to the gate.
Put on the R32 one in reverse order and that's it. It should be a straight swap out.
No settings unless you have a boost controller or something to play with
hey dudes
i changed the unit over
and i reset the ecu
boost is now around 10 - 12 psi
but im now loosing power and the engine is slightly popping at 4500 - 5500 rpm
do i need to replace the injectors or fuel regulator or a retune or something?
cheers
FYI,
The spring in the rb25det acuator is 7psi rated. Which is 0.55bar i think?
The 5psi is controlled by the ecu then after 4500rpm it grounds the black wire coming from the elec boost tap deivce and runs 7psi from the actuator.
I ran a rb20 actuator on an r33 turbo and it would run 5psi then after 4500rpm 10-11psi...I cut the black wire going to the ecu and then it never ran 5psi anymore..
Cheers
fyi mzturbo, it is not set at 7 psi. well, not on the stock turbo anyways. With just my stock turbo, I connectected the stock solenoid system up. Because I had exhaust and cooler, I was getting 9psi.
with just the actuator, I was getting 5 psi.
The solenoid is a bleeder. The actuator is 5 psi, it bleeds a little air above 4500 rpm, so it gets a few more psi. not the other way round.
Edited by MANWHORE
cheers
the joys of a misfiring skyline
there a billions of threads on misfire
increased boost = harder for spark to jump on plugs = misfiring
solutions? bringing down gaps on plugs = cheapsolution, you still have a weak ignition system
spitfire coil packs = $560 from sliding, it'll fix it
or you could do your own wiring up of igniter's and leads for $100-300, lots more work, theres a few threads about it here and on other sites
intercool is right,
my car done the same thing when is was in R&R mode as it did when it was misfiring.
I had 1.1mm plugs regapped them to 0.6 and the misfiring went completely..
the R&R a tune sorted that out..
ngk bcpr6es which are a .8 gap. It should help with the mis fire unless your coils are absolutely rooted. If it doesn't then either new coils or one of the many fixes that are posted in the maintainence sticky thread.
Dont worry about injectors and regs for now. fix the miss first.
Dude its just a standard RB25 turbo. You really shouldnt need to do much. Just keep gapping the plugs down until it stops miss firing, assuming that sovles the problem. If it does it still means your ignition isnt up to sratch (which is expected as the car is a good 15+yo). You could maybe just put the fuel reg on to be a little safter.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
