Work is hunting for a new gatehouse attendant, as you basically get to hang around the gatehouse all day getting paid to watch cars go past, thought someone from here might be keen:
Where: Manheim Fowles Vehicle Auction Centre - Redcliffe site
Description: Gate House Attendant, position available now
Controlling vehicles entering and exiting the site, including mobile and salvage.
Data logging vehicles in computer system and general filing
Controling access to site
Organising dispatch for auctions
Prefer someone with vehicle knowledge ie can tell the difference between a ford and a holden from sight
Will need some basic computer skills ie can turn the thing on and can remember your passwords
Need to have the ability to keep on top of things, as auction days do get busy, but other days can be quite slow.
Must have confidence to be able to direct public, and truck drivers.
Contact the Operations Manager - Brian Luck during office hours on 0417 589 412
https://www.sau.com.au/forums/topic/168192-full-time-job-available/
Whilst we are on the topic i have some work for the laziest of people for three weeks, have a 10 day break and then straight for another 3 weeks
in cockburn
12 hours a day.
days off as indicated above
take home 2 grand a week
All ya gotta do is sit down and record who goes in and out of a confinde work space
any takers????
Start immediately
  • 1 month later...
And another job for those of you who don't mind pulling some night shifts and doing some hard work:
I work 12 hr days, 5 days one week + 2 days the next week and I take home about $2500 a fortnight, call Integrated and get a job with BGC.
2500, seems pretty dam good for 7 days work? ;o
It is 84 hours and its spread over two weeks.
And yep its damn good just damn hard getting out of bed at 4:45am and getting to work before the sun rises.. then heading home after it sets again... ergghhh today was one of those days.. feeling a tad bit stuffed.
I'm in the wrong business... ffs apprenticeship hurry the f**k up and finish!
BAHAHA, yeah im in that boat too dude... few of my mates makin like $30 an hour on unskilled shit.... that really grinds my gears !
...fkin apprenticeships
i start work at 4am, do 10 hr shifts and i get 2K a month after tax... This is bs. bs bs bs bs bs bs bs. started at 4am on sunday, flat rate, no penalties.
Edited by Tofu
Look on the bright side, you finish your time and get ur papers and $30 p/hr will be a TA's rate to you.
Trade quals FTW!!!11!!!
    • I had never actually looked into it, but aren't onboard compressors a thing in trucks?
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
