Before everyone says it's impossible they are basically what giant says he is running (well the garret equivalents) and he's apparently making close to 400awkw's and has a 1/4 time of 10.2s run on RE55 semi-comps to back that up.
And I used to think giant was running -5's or something until I saw he's making 300kw's at 3,500rpm which you'd struggle to get with bigger turbo's.
So with the right set-up's, fuel and tuning it might be possible.
And I used to think giant was running -5's or something until I saw he's making 300kw's at 3,000rpm which you'd struggle to get with bigger turbo's.
300kw at 3000rpm? Are you sure this giant wasn't the main star in a story involving magic beans?
Just kidding thats a fairly amazing setup. I'd love to see the details of that. And i'd also love to be proven wrong about the GT-SS's making 364awkw.
That is HUGE average power if that is the case, no wonder his 1/4 times are so darn good. That would be a genuine 600+hp job... yeah? What a monster it would be on the street. :(
FYI since you probably don't check out the motorsport section - here's giants car doing a lap of wakefield in 1.04.2s (if you don't know thats pretty quick)
You can certainly see the way it pulls. But they are shifting at 7,800rpm which again shows they are smaller turbo's.
And here's another around some motokhana's that show's this car is always on boost.
If you want to know what's in the car read this
http://www.skylinesaustralia.com/forums/in...66392&st=60
I've seen this car in action and it is pretty damn insane.
I'd also like to know more about this paricular setup as its the most power ive heard of for GT-SS. I'd like to know how its done so i can do similar
What cams, comp, boost with what fuel, support mods etc and by Garrett equivellent i assume you mean the 2860R -7 ?
EDIT: Thanks, too quick for me!
and i'm guessing it's the reason (well one of the reasons) you are going back to N1s from the 2530s. :(
I personally am having a terrible time making up my mind between the SS and the 2530s.
things for the SS:
the are $500 cheaper than 2530s
they will be more responsive
things against them:
i'll have the same set-up as 90% of GTRs out there (yes I'm a wanker and like to be different)
the 2530s can make more power, and so many quick japanese GTRs are using them
i may need a fair whack more boost to achieve the same airflow (power) compared to 2530s.
but my power aim is between 320 and 360rwkw. with as much response as possible. it's a tough one.
hi Roy
i will try and tell you what we have found really important and our mods.
power is approx 380 to 400 kw's @all four depending on weather and temp.
so yep, still 2.6 bore size, 270 cams tomei, adj cam gears, cleaned up cylinder head ports, n1 valve springs,cp pistons, tomei rods, n1 oil pump with reinmax gears(also use tomei oil pump previously), hi octane racing large sump (will be going to a hi octane racing 4 stage dry sump in a month or so) standard exhaust and intake manifolds, are intercooler, n1 garret equivelant turbo's, greddy intake boost pipes, apexi airfilters, autronic ecu and cdi ignition,gonzo exhaust, vp109 fuel( good for 30kw's and much safer than pump fuel), tilton brake pedal box, australian spec tein suspension, bosch fuel pumps, advan suge tank, npc clutch ( i swear by it!!), carbon tailshaft. block and crankshaft are standard, acl race bearings, 25 row oil cooler, standard blow off valves. we also run a water sprayer for the radiator and oil cooler for longer circuit runs.
we have tried hard to make the power come on hard down low in the rev range , which makes it easier to drive, we tried aftermarket extractors and the car made more power but we lost over 500 rpm before boost would come on so we went back to standard manifolds, adjust cams to get power as early as possible, car has over 300 kw's at 3500 all the way to rev cut, rev cut we have lowered to 7800 till we get a dry sump.
the other thing we have spent a lot of time on is the 4wd system and wheel alignment setup, nearly all r32 gtr 4wd drive systems we have looked at including our car when we got it, do not function as they should. wheel alignments also have been a real issue. we have had a lot of trouble get alinment shops to align to the spec you ask for and ahen checked they are way out!! we now do all our wheel alignments by string line and have had far better results.
the car will be coming off the road in two months(after nsw dutton and maryborough sprints) for a full rebuild, dry sump if not before) , side exit exhuast for events that allow it, chromoly strut to strut cage, try to lighten it some, total repaint, stack dash , hopefully carbon doors, bigger swaybars & a few other changes.
hope this helps if you want to anything specific just ask
cheers russ
What a monster. Awesome setup.
He says Garrett equivilent N1s...?
Thanks a lot for the links. I have heard many things of this car previously which is why I never doubted what you stated about it. Just suprised to learn what he is running although he is running N1 equivs and not GT-SS equivs. N1's are bigger than SS's so I gather the Garrett N1 equivs are also a step up in size over the SS's. I don't doubt this output from N1's but SS's are another story right?
yeah, there are two versions of R34 N1s. one has .42 comp and .64 ex, the other has .60 comp and .64 ex. one is basically a GTSS, the other is basically a 2530. I'm not sure which one Russ is using.
I think you'll find most agree that N1's, GT-SS and 2860-7's = almost the same thing.
Yeah, Giant isnt running PULP. Thats the key factor.
I picked up around 40-50rwkw just by changing fuel myself way back when and laying on the timing thick and hard.
However, I doubt anyone has a hope in getting much more than 320-330rwkw unless your on the juice.
Project Mu - Dyno sheet and please tell us what fuel you are using, as you can clearly see from the RB26 dyno sticky thread that not one person has come remotely to that result on PULP.
So for me, its happy dyno love for your result
Hi
I just want to find out the max power available from HKS GT-SS turbos
I have 488hp at all four wheels (364KW) at 1.5bar (22psi)
Post your results....
Let me guess hub dyno? If so the power looks spot on. Hub dyno's shit on roller dyno's but they confuse the public as they read higher.
Edited by URAS
  • 5 years later...
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
