Most workshops do "test" cars because they don't have the tool/equipment(Dyno, road shock simulator, etc) to test them while stationary. Some particular problems may only arise when the car is pushed a little bit, but they normally don't do anything to excessive.
You should probably send a letter explaining that you were not in possession of your car that day, and it was being service at the workshop. You should probably also write a letter to the workshop, of what has happened and what you want them to do.
I know a few mechanics, and the good ones do test drive cars for problems. Generally I would stay away from dealer workshops as my mate have told me stories about fleet cars they have "TESTED", but they are softer a average persons car.
https://www.sau.com.au/forums/topic/168255-removed/#findComment-3111288
I was informed (by the car's owner) about a diff place southernside that crashed his corvette while "testing" with a mate from a different workshop.
Went through the courts and he lost out big time with only partial money being paid to him and the wreck returned. Since it's all on the official record I can probably tell you the name in open forum but anyone can PM me if interested.
I know one place I won't be taking my car.
https://www.sau.com.au/forums/topic/168255-removed/#findComment-3111613
I sent a PM to NJR myself.
Sadly it was who i thought it would be. They never sat well with me (mostly due to the stickers - i hate stickers the guys on the back of my rear window wont get any recommendations), although i was going to use them for my pending 100,000 service (christ i do a lot of km's) this has pretty much canned that.
And yes, particularly for our type of cars - and the way we drive them - there is a need to test them a bit harder than your camry or what have you. But this should be informed and we should consent to it - or they should bite the bullet and buy a dyno, then recoup the costs for it by providing a better service.
https://www.sau.com.au/forums/topic/168255-removed/#findComment-3112205
Hello Nathan,
I must apologise for your disturbing call from the police which would have been officer John Oliver Hawkins but the fact of the matter is that it was proven in court that I was doing approximately and no more than 90klph(''excessive speeds'') on a dual lane quiet road in Mitchell checking for pinging after having set the timing during the major service. This must be checked on the road even if I had a dyno, I don't know where he got checking the transmission from. It was proven in court that I was not speeding using video evidence taken from the police vehicle and from his witness an RTA guy that was with him and subsequently thrown out, I'm sure he didn't call you to tell you that he is a liar.
I will ring you once I get your number from work to explain why I was followed and harassed in the first place which has nothing to do with the way I drive or anyones car. All evidence is at my solicitors(he would not give me the video of the alleged offence) and you are welcome to it.
Regards,
John
I guess there are explanations after all.
https://www.sau.com.au/forums/topic/168255-removed/#findComment-3113461
thats good to hear, they've done alot of good work for alot of people on this forum. My car is there now and will go back there again if anything else needs doing down the track.
I really don't think anyone should think poorly of them there great guys and as you said there clearly are explanations almost calls for an apology :nyaanyaa: lol
https://www.sau.com.au/forums/topic/168255-removed/#findComment-3113497
Beh, i wouldnt call 90 clicks on a quiet road in a skyline, excessive nor necessarally dangerous, specially from someone that's driven so many quick cars. Wrong speed on the wrong road maybe, but it wouldn't effect my choice to use them in the slightest.
Actually driving the car on the road, loads a motor in a totally different way then does a dyno. If your shop cant check and cure your detonation condition at 6000rpm WOT then who can :whistling:
Shitty scenario man, hope you sort it out
https://www.sau.com.au/forums/topic/168255-removed/#findComment-3114220
    • It's been a little over a decade since I bought the S15. As I did on my socials, I'll share some of my favorite pictures from over the years further below. If you haven't realised, pretty much all the pictures in my posts are ones I've taken.  In terms of updates, I don't have pictures, but I acquired a near-perfect pair of fog lights from a friend of mine, so those got swapped in for the pair I already had. As for the JZX110, I just got it back from being fixed. A few weeks back, I was on the highway when I suddenly drove over something with very little time to react. It was probably the size of a soccer ball, but it went under the car and banged into the underside pretty loudly. I pulled over and realized the fluid leaking was fuel, and of course, it was right near my exhaust. This required replacing the fuel tank. If you happen to be in the same predicament, thankfully this car shares a fuel tank with the JZS171, IS200, and IS300, so it wasn't too painful to replace. Enjoy some pictures as mentioned above, including the carnage from the fuel tank and a bonus picture I came across which shows how ridiculously shiny the Bugels are on the 110. So many more pictures I could share of the S15 but this will do for today, enjoy.
    • Welcome.  Was the mistake the car, or joining us? 馃槒
    • Yeap, was me and the daughter getting coffee before heading to the new joint to measure up the fridge space and taking some pics that the solar installer wanted of the switch board
    • I saw a car just like this stopping at Harvest for coffee this morning
    • Factory Dash Lamps...Half the speedo was dark...T10 3 Watt Park Lamps...T10 5 Watt Tachometer Chip/IC...Tach would randomly go crazy or stop, replacing  capacitors and re-soldering the chip would work for a week or so but it would always fail again...AN8352UBK (Buy on ebay AU) Heater/Air Con Control Button Lamps...Grain of Wheat Bulb 12V...Tried LED's they fail after a month or so(even with current limiting resistors)
