Gonna Race At Calder Tonight...
i got a 14.00 @ 105mph. wayyyyy too much wheelspin in 2nd. i had to back it off from spinning. Woulda been good for a low 13 if i didnt have crappy 235 40 18's.
60 foot time was 2.40
Edited by R33GOD
try deflating your tyres a bit, i normally go 5 psi below 34 psi if i want to get more grip. don't know how well you launch, but i would ease up from 1st to 2nd smootly and do not miss any gears. 14's are not too bad, low 13's would've been more desirable ah?
i ran 18psi tyre pressures. still no grip. thats what i get for havin cheapy tyres.lol
did you warm up your tyres? went last week was getting similar 60ft than you but consistent 13.7s at 109mph running relatively low boost, using pirelli pzero rosso 18's going to try the same as you and put some semi slicks on stock rims and see if that helps, im going back this friday need to crack a 12. i have to get to get a better 60ft than that.
i have crappy silverstone 235's on it and they were unroadworthy. it was a good test. should be fun when i get the power to the ground
 Share
    • That's true. However, this problem has started since the tuning. First time with the return journey from the tuning. But yes, the pipe was clogged with dirt and rust. That was certainly due to age
    • Great info @tidi0x  Will definitely be handy for others and maybe me if I decide to keep the shit box H pattern.
    • Bumping this up one last time.... I wanted to follow up on the clutch slave issue. I realized that what the issue comes down to is the pocket is flat milled, and the cylinder does not want rest flat. So in order to mount it correctly you will need to make a spacer for the fingers so the cylinder is floating. I took two plates of aluminum, drilled some holes and was good. I did still need to make the relief cuts in the bell housing, as even with the spacer the bleed section still interferes. The OE bell housing the mounting holes are raised from the housing.
    • If the event in USA goes ahead will be interesting as it seems the rules will get more cars over here. Apparently the track is laguna seca too. Yeah s15, if I get a the lower dash trims, centre console and change front cross member to standard LCA position will fit clubsprint. See how rules are as i would rather do complete widebody than a bolt on flare to run the 295 with proper clearance.
    • If the car is legal height I can't see it being an issue. Found a thread on reddit that might offer some insight.   I got a ticket from a copper in QLD for my S15 being too low. They had this wheel thing on a stick that they put under the car and it hit my exhaust. Anyhow went to an exhaust shop to get the exhaust tucked up/hung a little higher and I wound the coilovers up a smidge. Don't think I even had to go back to the police station unlike when I got defected for having a carbon bonnet when I brought the S15 from the ACT to QLD and had to replace it and then rock up at a police station and have a yougish female officer who knew nothing about cars confirm that I had changed bonnets. Should have just painted the carbon bonnet yellow to match the rest of the car lol
