For sale: Hachi
Asking Price: 6k minus wheels and strut braces, unrego'd, NO SWAPS
Killometer's: 280 on clock dunno on engine
Manual or Automatic transmission: Manual
Engine Type: 4age
Condition: Pretty good condition, few bits of rust but nothing major, no dents, Newish paint.
Modifications:
Mechanical -
Bigport 4age 16v
Trd copy extractors
Pod filter
Bigger Radiator
Vl turbo Fuel pump
Excedy Clutch
Front suspension-
s13 CST coilovers
s13 lower control arms
r32 gtst master cyl
s13 hubs/brakes
8kg springs
Cusco Front strut brace
Rear suspension:
kyb short stroke rears
6kg ajps springs
AJPS rear strut brace
adjustable panhard rod
Wheels-
SSR 15x7 +10mm Meshies
fronts have been professionally restored and look pimp as
Bodykit -
streeter Front lip. with stitches guaranteed to add at least 10 degrees angle
streeter fibreglass bonnet
streeter sideskirts
Interior:
full interior, cracked dash, dished drift wheel etc.
Diff:
Can organise locker or open centre
Gearbox is abit tight downshifting to 2nd.
Can include another gearbox for $200 not that ive had any problems with it i drive it daily.
New rotors,pads and shoes, decent tread on tyres id say 70% rears 90% fronts
Has alarm, central locking, immobaliser
sunroof..
New rack ends ra60 rack ends and blue bird tie rod ends.
PM me or post here
NO SWAPS, i need money
Rust spots:
Cheers
Edited by DCNTLY
https://www.sau.com.au/forums/topic/168292-drift-setup-hachi/
    • Thread bump, again! Although, no bad news this time. Posting for the sake of possible root cause. Basically, I rebuilt it (mostly stock), installed Haltech + sensors, had it running fine on new ECU.  Still not really understanding why it cracked pistons last time. Got to tuners, and while checking timing, noticed +-10deg of timing scatter while revving. Changed CAS, and it was rock solid. While not definitive, can't imagine seeing 20+ psi with that amount of scatter would be a good thing. Also glad I found something.   Bit more of a run down; Carried out a stock rebuild, a set of stock pistons, out of a spare bottom end. Everything stock apart from head studs and oil restrictors. (so I can pretend I didn't let the Nissan out, ha.) Armed with the measuring gear and FSM, set about doing overhaul. Oil restrictors as per oil control thread for a RB25, stock oil pump, drifting. Head drain/vent from rear of head, to passenger side of sump above oil level. Two dash 10 vent lines from drivers side of sump (unused atm) Hi octane style cam cover breather kit Splash covers over last 2 cam caps. Both breather lines from cam covers to vented to atmosphere catch can, not plumbed back into sump (wanted to see what it was actually breathing). Got it run in (did about a 1000km) no to low boost scenario, As I had questions over old ECU setup. Installed haltech +sensors for flex Retune on E85 (finding CAS Issue along the way), made 300rwkw at 20psi, out of wastegate. Did a drift day the next day (yes, it was a big weekend!) and was checking catch can throughout the day, ZERO blowby. I mean nothing. Lines from cam covers are not even wet. Done a bunch of street driving, spirited and catch can is still dry. Early days I guess, but pretty happy so far. Also now run 10w60, up from the 10w40 that I used to run. Oil pressure is significantly better, especially when hot (as you would expect)
    • Thanks buddy. I thought it was a server storage thing. 馃ぃ
    • Perfect! Thanks for this, both look like great options!
    • but deep down inside once you Skyline, you always Skyline
