kjb_r33 Posted May 27, 2003 Share Posted May 27, 2003 Any one have one laying around, i need one to pull the plug off nad make an interface between a motec M48 and the existing wiring, so i can change between the motec and the OEM ECU. I have access to a M48 and just want to play around.... Link to comment https://www.sau.com.au/forums/topic/16832-clapped-out-r33-ecu/ Share on other sites More sharing options...
Guest INASNT Posted May 28, 2003 Share Posted May 28, 2003 I have a r33 series 2 ecu but it aint crapped out, its working fine. u can have it for $250. Link to comment https://www.sau.com.au/forums/topic/16832-clapped-out-r33-ecu/#findComment-349897 Share on other sites More sharing options...
kjb_r33 Posted May 28, 2003 Author Share Posted May 28, 2003 Thanks, but it would be a shame to destroy it, i would be pulling all internals out..... Link to comment https://www.sau.com.au/forums/topic/16832-clapped-out-r33-ecu/#findComment-349914 Share on other sites More sharing options...
Guest INASNT Posted May 28, 2003 Share Posted May 28, 2003 Originally posted by kjb_r33 Thanks, but it would be a shame to destroy it, i would be pulling all internals out..... destroy it i dont care Link to comment https://www.sau.com.au/forums/topic/16832-clapped-out-r33-ecu/#findComment-349915 Share on other sites More sharing options...
kjb_r33 Posted May 28, 2003 Author Share Posted May 28, 2003 LOL, i dont suppose you would... Link to comment https://www.sau.com.au/forums/topic/16832-clapped-out-r33-ecu/#findComment-349929 Share on other sites More sharing options...
Guest INASNT Posted May 28, 2003 Share Posted May 28, 2003 my pfc is coming this week so then i will pull out my ecu, so let me know Link to comment https://www.sau.com.au/forums/topic/16832-clapped-out-r33-ecu/#findComment-349936 Share on other sites More sharing options...
kjb_r33 Posted May 28, 2003 Author Share Posted May 28, 2003 thanks anyway, im sure someone has a clapped out one laying around, like i said, i want to make an interface so i can pull out mine and plug in the motec, i have access to that and a dyno so i just want to play around..... Link to comment https://www.sau.com.au/forums/topic/16832-clapped-out-r33-ecu/#findComment-349960 Share on other sites More sharing options...
Jay95R33 Posted May 28, 2003 Share Posted May 28, 2003 I just sold my old R33 ecu for $50... The tacho output was dead though Kep looking - they'll be one laying around somewhere.... Link to comment https://www.sau.com.au/forums/topic/16832-clapped-out-r33-ecu/#findComment-350177 Share on other sites More sharing options...
PranK Posted May 28, 2003 Share Posted May 28, 2003 i'd assume you wouldn't want a GTR one eh? Link to comment https://www.sau.com.au/forums/topic/16832-clapped-out-r33-ecu/#findComment-350217 Share on other sites More sharing options...
kjb_r33 Posted May 28, 2003 Author Share Posted May 28, 2003 are the plugs the same from a GTR and a GTST, id assume they are, like i said, i just want the plugs off them....... Link to comment https://www.sau.com.au/forums/topic/16832-clapped-out-r33-ecu/#findComment-350769 Share on other sites More sharing options...
kjb_r33 Posted May 30, 2003 Author Share Posted May 30, 2003 C'mon guys, surely there is one laying around, once i get the ignition expander, 3 bar map sensor and wide band lambda sensor ill be set to go, just need to make this interface... Got my little 1.6 litre to 80 Kw at 5000 rpm yesterday (engine dyno). Dont want to push it till i have my fuel maps ok above that, but hitting just over 8 PSI boost with .84 lambda at 5000. Link to comment https://www.sau.com.au/forums/topic/16832-clapped-out-r33-ecu/#findComment-353837 Share on other sites More sharing options...
