ive seen this happen. time for a tune up. your engine is not handling the thrashing well. could be a range of different things. depending on how exactly stalled. ie. as soon as rpm drop back down to idle state. or did it idle for abit then stall. EAch of these things signify different reasons and different things to check. speak to a tuner.
  • Replies 49
hey all
i hope someone ca help me solve this mystery.
the other night i decided to see how my car would go at really high speeds (now im talkin i got up to 170k) the car did well, held it togther nicely, but............i threw it into neutral to put less strain on the engine as i slowed down.........then she stalled. f*** knows why!??
Im thinking maybe it was cause she was at such high rpm????????? please help! this is so weird! cause the the highest i can go is 180 km so i dont understand why!!!!
170k,not cool would you like to see the result of 30k's over an comin un stuck
you's all act like you havnt done it before, which if you say it, i call BS
everyone does it atleast once, if there was no one aound her, no one in the car, she only put herself at risk which is just like if she where on the track
not that im saying i condone it
but just a note, you should have let the engine brake, i wouldnt clutch in/put it in neutral and then coast at those speeds, you want the engine to help you slow down.
NEVER EVER DO THAT AGAIN.....
This is what may have happened:
I don't know about R34's but in my R33, someone TOLD me that it has soemthing to do with my ecu not being able to correct the AFR with the blocking of the recirculation valve, or the unlikely event that too much air would be entering the engine, causing a stall, not sure how accurate that is.
Edited by Pauly33GTS-t
I agree with what Eug said. Its probably something to do with such a drastic change in load.
Are you stupid? Why would you do that? What was wrong with leaving the car in gear?
Have you heard of engine braking?
Sorry its just thats a really stupid thing you did. No offence. How can you be in control of your car if it isn't running?
the ecu made the car stall because it was reading too much air for idle than normal, thus f**kin up the AFR mixture and making the car stall, my guess. ie, the ecu couldnt correct it in time.
lol eh?
Edited by silverbulletR33
... are u from ns.com. go back there if you are.
I'll explain what I meant to say when I come to grips with what I wrote.
This is in a N/A section why are people talking about turbo's in the first page, is it a turbo converted NA?
The revs and the air flow into the motor drop far to fast for the ECU to keep up and causes it to stall, I'm guessing you probably have a vent to atmosphere BOV which doesn't help the situation either. Best idea just put it in fifth gear and brake.
My mistake, I got the wrong Idea from this...
CArs that do that. tend to be out of shape. Ie. need tune. clogged air filter. thrashed engine. dirty idle control circuits etc. the car should come back to idle fine. Not a big drama. but thats hwy i said 'Time for a tuneup"
but she had been tuned up only a week and a half b4 it happened. air filter was changed (pod filter), fuel injectores have been cleaned out. and a service ws done about a month ago (not even!)
anyway thanks everyone! its not something im gonna do again. its just not worth it.
you know full well that i'm not out on a personal vendetta or anything.
but i'm sorry to say no that you do not have full control of the car.
with the car stalled you have no power steering, and braking is very limited.
that aside, being in full control of the car still doesn't justify it.
i'm thinking oil pressure could be your problem? not sure, i don't know anyone else who would try/think to do something like that.
what the hell? power steering is done electronically...
turn your car power on without turning over the eninge and turn the wheel...
other then that, dont speed...
wtf ?
Anyways, My magna kind of does this. If i boot it and then throw the clutch in, the revs drop to like 200 rpm then bounce back up tp normal idle
hi ur car looks good but im so confused why would u put ur car in neutral doing 170 this is beyond me someone explain. anyway i would say that because u have put it in to neutral ur ecu is gone wtf and stalled and gotten confused and stalled. i say keep the 170 180 for the drag strip and please dont do that to ur poor car :D
but im not here to bag u out no offence intented
i had this problem while i was running a pod (only at high speeds is it a problem 80+)
i figured the AFM couldn't keep up with the rapid change in air pressure and it stalls because of that. no probs since i changed back to standard airbox
yeah i think its something to do with the massively high load on the engine, with it sucking heaps of air, then with no backpressure in the intake due to the poddy, the airflow has just stopped, or created some sort of random turbulence giving the afm an incorrect reading, causing it to over fuel/under fuel, or starve it of air.
anyway moral of story, leave car in gear :)
its all well and good people saying dont do 170 etc, but if she's in the situation where she needs to /can i.e. the track, it would be equally dangerous for the engine to just stall
hey all
nm
Edited by CCCP
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
