Im now distributing these fuel pumps here in Australia for advtekk in the united states.
They are fantastic pumps and suit most vehicles, rated at over 500hp and very quiet.
Details can be found at:
WALBRO
They are $165AUD delivered which is great compared to petrotec at $280AUD.
Payment is via paypal.com to the user [email protected] ,please write name and address in notes field. I can be contacted between 9am-9pm on 0400494846 or emailed on the above addres
Note im not a business, just buying in big numbers to make a cut. That is why they are the same price as they can be had at advtekk.
WALBRO
https://www.sau.com.au/forums/topic/16836-walbro-pumps-fs/
alternativly you can now deposit directly into my stgeorge accout. Shipping is usually under 2 weeks, install you can do yourself. Fit all skylines, any jap imports. just let me know which one so i can match the install kit provided. Give me a call on 0400494846 with any q's or to obtain my acc details. 105USD if using paypa or 165AUD if depositing into stgeorge accoutn
https://www.sau.com.au/forums/topic/16836-walbro-pumps-fs/#findComment-353224
neergnevets, just inform people that these pumps are only good for 200rwkw.
its missleading to say they are worth 500 hp, or can handle that.
i bought one and then found out it wasn't rated at 500 hp.
the 255 litres an hour is an no pressure.
but when you are on boost and when you car is most likely to blow up it only can only run 185 litres per hour.
If its a different pump than the in tank silvia one then i am sorry.
but just so people know what its really rated at.
still a good pump for the price.
but 200 rwkw isn't that hard to churne out in the rb25det
https://www.sau.com.au/forums/topic/16836-walbro-pumps-fs/#findComment-367226
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
