my car battery is completely dead , i have d/c the positive lead from it because my alarm wont stop sirening . this is probably the back up battery for the alarm . and everytime i connect it , it keeps making the siren .... hence the car is dead .
what am i to do next ? im stumped . im considering calling the NRMA , but if i cant do anything what could they really do?
any answers would be great ?
https://www.sau.com.au/forums/topic/168362-car-battery-dead/
buy a new battery or charge the one you have now.
there a three reasons a battery goes flat, alternator not charging properly, a current draw or a dud battery.
if ur a NRMA member then give them a call as they can help u
my old man said if you get it started, drive it around for an hour and then can't start again then the alternator is f**ked.....otherwise something must be draining it
It could also be that the battery is cactus. Thats what happened to me, it would ONLY JUST start after an hour driving around. Then got a new battery about 2 weeks ago. No issues since then.
:stupid:
this all happened because i had the stereo left on for a few hrs .... jumped it twice since then , but havent fulley charged it cause i cant drive for another 4 weeks .. so its gone flat again , because one nigth i went out and was working on my car and had headlights on ... drained again ... although , the other day i walked by my car and checked the door if it was locked , and the alarm sounded cause it was armed and opened ..... the remote wouldnt shut it off , cause no power - so i dcd the battery ..
i doubt the battery is gone , i think its just completely dead ..... and to the point where it wont charge through a jump .
how much is a new battery? if i called NRMA they could bring one , so iv heard...
between $30 for a super cheapy to $120 for a decent one.
(the more you pay the more plates per cell you get in your battery)
i suggest if you have a problem of draining your battery you should invest in a battery charger.
to check the charge rate, start the vehicle grab a multimeter and set it onto voltage.
turn off all your lights and air con and place the multi meter on the battery if its reading a constant high 13V or low 14V thats good, now put some load on the battery by turning on your stereo or lights and do the same as above it should now read a constant low to medium 13V.
thats the most accurate way of checking if your alternator is working.
to check for a current draw have everything turned off inc your ignition. disconnect the negative battery terminal. now set your multimeter to amps and place one multimeter cable on the battery post and one on the terminal. your multimeter should be reading 0.10 -0.01amps if its around 0.2 or higher then there is a current draw.
to find out where the current draw is coming from keep the multimeter as above and start removing and re-fitting your fuses one by one until the draw goes away.
this just narrows down all the possibilities of what could be drawing current.
    • I’m only posting this cause I thought I had seen a bad review on these somewhere before. Any feedback? Would you guys recommend that if I do buy these I send em to RC to have em checked before installing. Or any other suggestions?   https://www.ebay.com/itm/114009965865?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=JDl-15yLQ8C&sssrc=4429486&ssuid=QTzlFXB1S-S&var=&widget_ver=artemis&media=COPY
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
