what u guys think of $50 bosch bov's?
Blow off valves are blow off valves. Purchasing an aftermarket brand name BOV doesn't always mean its a quality product. Leave your stock one on unless its leaking. There is no performance gain in adding an aftermarket one. Save up for a worth while modification that you will benefit from.
Sorry didn't answer your question very well. Yes the Bosch BOV's are decent. I had a friend with one installed on his VL Turbo and it was loud. Did everything a BOV was supposed to do.
boys boys boys. The Bosch BOV is a great blowoff valve, CAPA actually use two of these on all of their aftermarket Supercharger kits for Commodores, Falcons & Nissans - 6's and 8's...
Volvo, Saab and even some other european turbo cars use these from the factory...
I will only say this once: A BOV will only work best at holding pressures when it is mounted in the proper the location, (before throttle body is best) and whether or not it's vacuum line is receiving the same boost signal as the boost pressure that is trying to push the BOV open... This will ensure the BOV remains shut (no leaks) when both sides of the chamber have equal pressures. When you let your foot off the pdeal, the boost signal travelling along the vacuum line suddenly disappears (closed throttle, no positive pressure in the manifold) forcing the BOV open by the boost pressure trying to get past the throttle butterfly(s). Simple. No S*** i hear you say...
Well most factory BOV's leak because they are usually located after the turbo and before the intercooler, therefore when you increase the boost, the pressure drop across the restrictive intercooler core causes a lower than expected boost pressure to travel along the vacuum line (from the manifold) to the BOV, which causes it to leak.
The Bosch BOV is going to be exactly the same as your original BOV, but offers people an option when they are going to have a different inlet piping and want to ditch the stock setup. It's more functional rather than w**k value compared to other aftermarket valves, i reckon. Can be either rigged up to vent atmospherically or be plumbed back to the intake.
Part# 0 280 142 103 and can be bought for under $50 if you're lucky and know someone who has an account with Robert Bosch..
to have the bosch bov venting to atmo without an AIR FLOW METER's car stalling, you will need to modify the bosch bov with a one way valve.
otherwise you MUST have it plumb back (unless your car doesn't have an air flow meter.)
if anyone wants details on how to make the bosch bov able to vent to atmo, I can post a link.
    • Well some mostly good news and some slight bad news.  Good news is cylinder 6 did in fact only require a honing and I'm good to run my 86.5mm pistons again. I should also get the block back by end of week. Bad news, had a few surprises pop up. First, main and rod bearings were trashed. No sign of any heat damage. I knew right away what caused this... I had not packed my oil pump originally and spent a lot more time than I would have liked cranking the motor to get oil pressure. It sounded fine once started so I chucked it up to luck and forgot about it. Luckily rod and crank are fine and just need new bearings. Engine builder agreed that this was the cause.    Another surprise that carbon covered up very well that I didn't catch, something got sucked up and went through cylinder 1, 2 and 3. Luckily this was no cause for concern, just needed a bit of cleaning up. Valves look fine but he will vacuum test the head this week to confirm. I'm presuming this was something left over from welding my intercooler piping, but we'll never know. I'm going to thoroughly reclean everything.    So all in all, happy the motor is fine, and I'll get it back much sooner than expected. I'll also be taking the time to convert my WMI system over to direct port. I'll snap some pictures of that when the parts come in.
    • I understand, thanks. Yeah I wouldn't want the car to tip over, I'll try and use the sills, I don't want to risk smashing the chassis rails. I ordered some rubber pucks that have a hopefully big enough slotting. If the front right gives me trouble I can always just make a wood block. I'll measure and inspect the sills closer once I actually take the car up. I hope so, but the rubber blocks I had in hand so far were pretty damn firm, if they are that hard they won't give much way. I'll let you know what happens. Angle grinding rubber isn't one of my favorite tasks. I'll probably start a build thread soon, for my own documentation and "log" as well as sharing what's going on with the car.
    • Kinda something I have been thinking about.  To be honest, we bought it already driving like that.  So there's no telling how long it actually has been driving like this.  Hopefully damage is too bad when we drop the pan.   I am having a hard time finding a site that sells the solenoid for the 5 speed auto, do you have any suggestions?
    • That'll be most likely down the road...  LOL
    • a stock / option or aftermarket?
