yeah ditto. I always thought a trip computer told you km's you've done, how much fuel your using per 100km and how many km's you've got left before your empty. Not that a stagea needs that. Answer is simple... not many + shitloads = bugger all :)
https://www.sau.com.au/forums/topic/168440-trip-computer/#findComment-3115043
I know the S2 RS4S came with 4 wheel steer (HICAS).
And FAST shows an option for what they call a "Meter Multi" looks like it has a compass and such, maybe this has a trip computer combined.
It mounts on the dash instead of the clock.
https://www.sau.com.au/forums/topic/168440-trip-computer/#findComment-3116337
^^yeap - they also have an option for the trip computer to be put on a HUD so there is one available, but I think its as rare as chicken lips.
I know that Nissan used to advertise the twin odo's in the series 2 & 3 bluebirds as a "trip computer" so the stagea dealers are prolly just going along with that.
https://www.sau.com.au/forums/topic/168440-trip-computer/#findComment-3116383
meza got the hud but no trip computer i think . all its got is temp, compass , time ,and i cant work it, its got some buttons im not shure what they do but it still looks flash
picsorban :(
https://www.sau.com.au/forums/topic/168440-trip-computer/#findComment-3117958
  • 1 month later...
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
    • @Duncan Random side note, did the cops give you the driver/owners details of the taxi and then did Shannons give you a refund of the excess once you supplied those details?
    • Yeah to be clear I'm not naive, I'm sure all insurance companies are a bunch of arseholes who pay people bonusses based on the value of genuine claims they avoid....I just don't want to go back to one that has personally f**ked me multiple times in the past
