Your wallet.
That's the simplest answer.
I did approx 35x 7000-8000rpm launches (about 30 of those at a prep'd drag track) in my R32 GTR in 8mths without any issues (best feeling in the world) but #36 has cost me about ~$15,000 (flywheel shattered, ruined my firewall, chassis rail, engine, gearbox, inner guards etc etc - the car is effectively a write-off) and has very likely put me permanently out of the import 'game'.
It's always the weakest link that goes first (naturally) but their is always a weakest link. Upgrade your slipping clutch then 1st gear goes, fix first and your axles break, fix the axles and the diffs go and so on.
yeah but after you fix all the weak links you go reallllyyyy quick.
random q, but all those urban legends on the next of clutches coming apart and cutting feet off and stuff, did any part of your flywheel pierce through into the cabin?
It's not an urban legend, it's a fact - Ben is very lucky to have functioning limbs after his clutch and flywheel shat themselves.
Faark.
Sorry to hear about your mishap, thats the biggest one i've heard of for a while.
One owner of a genuine 500 bhp road going GT-R told me he only ever ran a single plate clutch, as he preferred to replace it every 12 months or so rather that all the other driveline components.
Their are plenty of pics available in the drag section titled 'August 12th' (2006) or something like that.
When I got my car home the only visual damage inside the cabin was the plastic foot rest had popped off it's bracket.
After we removed the entire dash, pulled the carpet back we could see that the firewall had taken a massive pounding from the gearstick forward and the 4wd prop shaft had been lodged 2 inches up into the driver side floor pan directly below my left leg (had to hit it with a hammer to remove it).
The passenger inner metal guard between the strut tower and firewall (where the ABS + wiper motor is) does not exist, it was ripped clean out along the welds.
A piece of metal (unsure whether it was flywheel, guard, bellhousing or something else) ended up 50m away in the crowd and the only physical piece of flywheel I have left is the size of a 20c piece.
I won't make another appearance at a drag strip until I have a good aftermarket clutch and flywheel and at minimum a ballistic blanket around the gearbox.
I had approx 550bhp and a single plate clutch (Jim Berry - best clutch i've ever used) and it still happened. I'm sure that if I was using a cheap crappy clutch it wouldn't have lasted the ~35x 8000rpm launches I did and I would have had to replace it with something better and replaced the flywheel at the same time which may have prevented all of this happening.
I wont be running my rebuild at least until there is a safety blanket or scattershield to protect both me and the car from this shit.
It isnt a myth, I saw 2 examples of this back in the old surfers paradise drag strip days. Its darn scarey stuff.
and bi metal fly wheels r the worst for doing this (alloy flywheel and steel ring gear)
and the diffrent expantion rates between the 2 metals corses the metals to put more pressure on each other and eventually something has to give
brett
    • As GTS mentioned, it takes a bit of faffing, some fiddling and a little modifying.  With the strainers, you can buy different styles. Some sit flat on the pump, some angle down.  Here are some photos of mine, ignore the ugly welds lol.
    • The smart thing is to actually locate the pump at the right point down the hanger, so that the strainer can stay sticking out at a right angle, but near the bottom. This is the perpetual hassle with retrofitting any different pump to the factory hanger. Some just go where you need it to, some need fiddling and faffing, and modifying of stuff.
    • Some updates. After a lot of praying and some inspecting of crank threads, we've found that they were both kinda munted but nothing seemed terminal. The other option was drilling and helicoiling the crank. That is obviously the last option so we decided to at least try to get a OEM GM bolt in to GM Specs. So after honing/linishing the balancer from it's .002" interference fit to a .0018" to .0015" to .0013" it eventually slotted on to the crank. ATI state the interference is nominally 0.0007-0.0009... so it's still snugger than ATI reckon and explains the issues we had to fit the thing to begin with. New GM bolt went in at 37 ft/lb then torqued 140 degrees after which was EXTREMELY   but it tightened up to 140 degrees and it was a lot of force. So all things considered, the balancer is secured to the exact specs that GM want with the OEM Stretch bolt, (that ATI say you can use..) and the balancer itself is seated and snug AF. So WOO. Engine is now back in the car with lots of swearing. Bellhousing bolts done up, driver side manifold is on, AC Compressor and hard lines are back on the car. Next step will be to connect various engine bits/wiring/intake/radiator etc. Then oil and coolant and ... test start it? And of course, looking into this issue... which actually doesn't look so bad - It looks like it can be twisted back into shape with a set of multigrips. Anyone wanna buy my bonnet? Boy it looks good over there and sunk cost sucks.
    • Also this may be a stupid question, but how would you recommend getting the strainer on a downwards angle ? as they tend to obviously clip to the bottom of the pump which usually sits level 🥴
