Okay. I figured Id get one of my cars running good so I can sell it and I had a S2 25 kickin in the shop so decided to toss it in. Everyone that’s done the swap has said its easy as pie so I searched for hrs on this site and came to a few threads with information on RB25 conversions but some of they’re info is wrong and colors of wires are wrong and half the time you cant even understand what the hell they’re talking about because of they’re punctuation.
Below is some of the info that I have put together from other members on this forum. I need to sort out the junk and get the correct info. When im done with this I will edit this page and have a step by step for the S2 engine. I will have PICTURES and actually tell you guys what the wires your cutting up are for and not just letting you know you need to cut it like the rest of the info on this forum. I can do this within a few days if I can get some help from you guys.
***I found this on another old thread from another member:***
Now for the wires.. I didn't hook up A/C as there was none.
In the R32 engine bay there are 2 plugs by the passanger side headlight.
You use 3 wires from one of them only. The other plug is for an Auto.
The 3 wires on the R32 are (Black/Red, White/Purple, White/black) the 2 large ones, are for the power to relays etc, the White/Black is power to sensors etc.
Now in the same location there is a single plug that runs from the RB25DET. From this it is only the grey wire that is spliced into the Black/White on the R32 plug. This is power for the injectors.
Under the dash at the SMJ you need to run 3 good sized wires up to the 3 in the engine bay on the R32 plug.
There is a Red/Black, Red and a Black/White
R33---------------------------R32
Black/Red---------------->White/Purple
Red------------------------>Black/Red
Black/White-------------->White/Black. (has the grey injector wire also attached to it.)
NOW WHAT I THINK:
Now I cannot find a Red wire or the Black/White wire on the R33 SMJ. I found a black/red one but that’s it. This is the important part I guess. I really need to know where to hook these 2 wires in the engine bay to the SMJ. Thanks
This is all that is needed for the car to run.
Now you just need to attach water temp, fuel pump relay and tacho under the dash.
On the R32 under dash loom there are two plugs. The colours are similar.. you need to use the ones on the smaller or the two. 14pin. The other has 18.
R33----------------------------R32
Blue/Black ---------------->Blue/Black. Water Temp. ( you also need to use the RB25DET engine sender. (single wire)
Yellow/Blue---------------->Yellow/Red. Tacho
Black/Pink------------------>Black/Pink. Fuel pump.
NOW WHAT I GOT TO SAY ABOUT THIS:
I found all 3 wires inside the car just fine but when I went to match these up with the 3 others on the R33 harness's SMJ I found 2 yellow/red. I was like okay… I will just see if I can find the other end's of these wires at the Coil harness for the tach signal. I did see one yellow/blue wire on the TPS Sensor but couldn’t find the other one. I DID find the other 2 wires.
Sorry for the long post. Most of you guys might not even read this but any help on this will be very helpfull!!!!
Edited by RB30 Ceffy
It's been so long I've done it (12 months), I am probably not much help..
But not *all* of the colours match...you're best off with the pin diagrams from the ECU's..
I do remember the yellow/red and I believe one was just auto only... TPS also has an extra wire for the auto ecu to decide the kick down and things, but that is not required if you're going manual.
With your relays, the red I believe you just need to find a 12v constant, or 12v IGN (I forget which), as the r33 ecu is slightly different with the relays - and those wires don't go up into the engine bay like the 32 does. The thick black/white stripey is ground *from what I remember* so can go to chasis.. but anyhow, make sure you check.
My memory is so rusty, I really need to check the wiring again.. but that would require pulling out everything at the footwell.
    • To be fair passengers who aren't silly and have been in proper fast cars have often been pretty impressed once you hit 4th gear
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
