that is f**ked. i was soooooooo close to going on that drive. i rolled thru thornlieh maccas at arond 10pm ish. but i was tired and in my work clothes. so i kept on my way home.
oh deer. people try too hard up there sometimes. now its for sure a no go zone from here out :s
condulances to all involved :)
https://www.sau.com.au/forums/topic/168460-death-on-oph/#findComment-3113648
As bad as this is, be glad it wasn't a skyline incident. U guys already have a bad enough reputation as it is (no fault of your own). Still sux that this has happened. Hope this is a reminder to everyone, BE CAREFUL!!!!
https://www.sau.com.au/forums/topic/168460-death-on-oph/#findComment-3113668
We were wondering if that was you. Looked like your car, but the rims were black and it didn't sound as loud as normal when you left.
If you'd gone on that cruise you may not have been involved - this accident was with a different cruise to the one you saw.
Edited by scathing
https://www.sau.com.au/forums/topic/168460-death-on-oph/#findComment-3114852
    • If you are genuinely considering trying to get this engineered, I would strongly advise finding the engineer that is happy to sign that off first before you put the hole in your car.  I've seen cars get defected for this and not be able to be put back on the road as no engineer they spoke to was happy to sign if off.
    • Apologies, while id like to put the MAF as close to the TB and relocate the recirc, this may be too much work. Will most likely end up just putting it on the original AFM spot ( onto/next to the airbox ).  Was going through nistune, found a pretty nifty doc on this. Nistune MAF Notes. Also, i was looking through the bay, and there seems to be a tube/line connected from the A/C to the intercooler piping ( Between the smic and the recirc), what does this do as the crossover fmic piping doesnt have any connection? plumbing? not sure what you call it but the nipple thing ahah.  Also, been reading up more about crossover fmic in regards to the legality of having the hole drilled for the piping, this would most likely need to be engineered right?
    • My advice is if you need a big build done do it in Japan. The yen rate is so favorable and there are shops that can be genuinely trusted and not micromanaged/carefully monitored every step of the way. Garage Yoshida is obviously my preferred option but they're so busy these days and all interaction with new customers has to be mediated through BBL/Toprank now.
    • I haven't....but a poorly made one would terrify me. Surely a good second hand one is the go, as they don't work hard and no-one wants to keep one after they are finished with it A big consideration would be the weight of the shell you are putting on it....is it a fully dressed chassis or just the body
