So you have an aftermarket guage and factory one?
could be a few things, both wastegates stuck open (not sure why that would happen)
big boost leak (but then car should run rough as it will be running very rick when losing all the air after the afm)
if they are ceramic turbos the exhaust wheels could be shattered?
what mods std afm and computer system?
yeah an apexi and a stock guage
both needles dont move a bit no matter how you drive, and even at idle.
ive had a leak before and the car ran like shit and usualy stuff comes out the exhaust
they're n1 turbos and the boost has never been overboosted to a dangerous level
usual mods
cooler
pfc
ebc
im just stuck to understand why the guages sit at 0..
well then have u checked where the guages are connected? if they read zero at idel something definatly wrong. are they plumbed in independantly?
you will have vacume at idel, if the guages have disconnected then they see atmospheric pressure and stay at 0 at all times.
Edited by GTR1993
i'll go check again now, but they all end up in the same spot near the firewall drivers side.
    • Hey, it's me! Though honestly, if I had 20M in my bank account tomorrow, I would not want to be rid of my car all of the sudden - Which makes me think this is money stuff, not "I actually hate car" stuff. I'd probably double down and buy even more trinkets and fun things for it. If this is not you, then sell it cheaper. It will sell at a certain price after all.
    • This is the LCA mount reloctaion kit. Self explanatory in its description. https://au.gktech.com/products/s13-180sx-r32-subframe-anti-squat-reduction-weld-in-kit?_pos=62&_fid=1e812d392&_ss=c These are the alloy subframe bush inserts that I am using. I like them. https://au.gktech.com/products/rear-subframe-slip-in-collars?_pos=29&_fid=1e812d392&_ss=c Alternatively, if you have original and shitty bushes, you might consider outright replacement with poly. https://au.gktech.com/products/polyurethane-rear-subframe-bushes?_pos=28&_fid=1e812d392&_ss=c I would also higly recommend that you look into adjustable RUCAs and tension rods, so you can sort out the camber and bump steer behaviour, especially if the car will be any more than ~15mm lower than stock. I would also highly recommend the GKTech FUCAs, although you really should do some research and learning on the subjetc of R32 FUCAs before making any decisions. All of this will be criticaly difficult to get through a TÜV inspection too, if that happens to be relevant to you. Note that if you do install the relocation kit, you will absolutely have to replace the associated bushes with spherical joints (you can read all about that on the product page) or upgrade the LCAs also.
    • I picked up my block and head last week and have been slowly assembling it since then. Pictures I took earlier this week. The rest of the auxiliaries are on now. I just have my intake manifold runners to tap for my WMI direct port setup before putting it back on. I should hopefully have the motor back in by this weekend.
