On thursday i picked up my skyline, I had the weekend to drive around and get used to it. the twin plate clutch is a bitch but im slowly gettin used to it, and the power too. :)
But when i first looked at the car i noticed there was no cat. however i couldnt remember what the exhaust looked like on the day,but the guy said hel put a cat on for me.So when i picked it up i had a look underneath, and i noticed it has the 3" turbo back but there is no sign of a flanged cat.Now from the turbo down until about underneath the back seat there is nothing then it looks like there are 2 resonators one about 6 inch then just after is another one about a foot long then it goes back to the muffler and out.
SO can it be that the 6 inch one is a high flow cat. because there isnt a flanged one in there? if anyone has pics of what a high flow cat lookes like please post em up.
il get some pics tomorow on the situation. i really dont want to get hammered by EPA for no cat.
cheers
Neil
https://www.sau.com.au/forums/topic/168507-finally-got-my-skyline/
If it's welded on and not flanged bolted in then theres a good chance they're both resonators. How big is it at a guesstimate in diameter? You said 3 inch piping, so if it's only around 4 inch and is circular, like the foot long one then probably resonators. most of the high flowed cats i've seen have been pretty angular and at least 4 inches and 6 inches across. Get a pic of it if u can but i'd say they both just resonators
thats a nice car, i had one as well. In my opinion the Series II is better then the original. Series one reminds me of a magna when seeing at at the front, where as this one has a sharp look to it. I had heaps of mods on it as well, apexi power fc,intercooler,injectors, sway bars,exast etc etc etc i had it all apart from the turbo,
still i made 203.13kw at the wheels on 15 so it wasnt too bad... trust me man keep the car they are really nice, and congrats once again
    • Oh, there's also the gearbox crossmember which will probably be different between the small box and the big box, and the wiring loom will probably need to be modified, because the plugs for the switches etc, will probably be different. And I think the speedo on the small box R34s is from somwhere stupid, like the diff, possibly, so you'd need to work out what needs to be done about that (assuming it is different). I think the thing you need to realise is that the front end of that yoke is a large hollow tube with splines on the inside that mates with the splines on the box's output shaft. It is a dedicated thing - not available "aftermarket". They were made to suit that box, by the car's OEM.
    • You need to buy a Saab Matt, ours had a button that turned all the dash lights off. Any decent aftermarket dash has sufficient brightness control and a headlight input for day/night settings. None of which probably helps OP
    • Yeah thanks...i thought it would be alot more i dont know 😄 I saw some videos on converting push/pull and it seems you need to "drill" the hole for slave(master) cylinder and buy some converter kit. On that front yoke clip i did not even know that is a thing and i need to source that(custom shops do not do that?) But anyway thank you for the info
    • Not the headlight. It's the DRL that serves double duty as white and amber. Would be the easiest way to make it happen, if fitting a BCM was in any way an easy thing. Otherwise you'd do it with some relay logic and/or maybe some diodes.
    • Would require a very smart body control module which these cars are about 20 years to old to have
