Rb25 Powerfc 8channel Readouts @idle
kegz
 Share
hey guys just installed my powerfc and i would like to see how my car idles agenst other 25's
i would like to know what other peoples readouts are on the hand controller went set to 8 channel monitor
just so i have an idea what my idle should be.. cheers
WtrTemp when the engine is warm and stable should be around 70 to 80deg.
Knock at idle should be 0 or like 1 or 2 at the most. Give the engine a few revs, ensure it returns to zero.
BatVolt should be around 14 at idle. Too low is bad and Too high is bad. over 15 is bad and under 14 can also be bad.
Airflow should be stable at idle, around 1100mv (millivolts). Should increase when you give the engine a rev and should return to around 1100 ater it returns to idle
EngRev should be similar to what the stock tacho says, it may be out a little bit. Ensure it follows stock guage when you give the engine a rev.
InjDuty should be around 1 to 2% at idle and should increase considreably when you give the engine a rev.
Boost (if not using the boost kit it will be ---) should be around -500mmhg at idle and should goto near 100mmhg with a free rev.
IngTmng at idle should be around 15 or 20deg. Should increase considerably with free rev.
yeah my timming is 22deg
and my RPM is 550-640
air flow around about 1200mv
how do i get a knock reading that isn't in a bar graph? eg numbers
From memory, i use 4-channel mode, so the numbers are bigger - and i think that displays knock as a number. I also have the max values displayed alongside, i think you press right, or up, or down on the controller to turn this on or off.
 Share
    • No I’m just reading shaking my head
    • Yeah, after my first post i did notice that my tps wasn't calibrated exactly to the tee. So I did calibrate it: applied the settings, rebooted ecu and it's still the same.
    • Lololololol... Poor bastard will read all this and have a sads.
    • Dry sump? Is that like where you don't put oil in, and leave the car parked in the garage because it's worth so much now and is like a beautiful museum piece? 😛
    • Nissan Fuga Y50 2009 VQ35HR 313 hp / 230 kW RWD Also sold as Infiniti M overseas. Performance sedan built on the same chassis as Skyline V36 or Infiniti FX. Great colour with a fantastic velour interior. Very quiet and fast car (<6s 0-100), but can also be very economical for performance (long-term average consumption 11/100 km) I imported it five years ago, and it was well looked after. It has a full service history and a balance of ACT rego. There are no finance or PPSR issues with the car. Has all the features you'd expect from a luxury car. ABS brakes Stability control Traction control Dual-zone climate control Power and memory front seats and steering column Power passenger ottoman Smart key access Push button start 2 parking cameras Steering wheel audio controls Adaptive radar cruise control AFS aiming headlights Xenon HID headlights Security system Original Nissan remote start system Two original keys Dual-channel dashcam Blackvue 750 with PowerMagicPro for battery-aware parking recording Regularly serviced with a lot of major items done: Full new original Nissan suspension shocks throughout Performance CSF radiator Recent tyres, less than 10k on them New drive belt New bonnet struts Brakes recently done The car comes with a fully converted AV system with Australian GPS maps, DVD, and radio ($2k job). I really love this car, but I have too many cars and too many Nissans in the family, so unfortunately, I need to sell it. Priced at $18500 The car can be seen in Curtin. Thank you for your attention.
