I need to sell my beloved 'Line because I have already bought a new car and I need to vacate the garage for my new ride.
The car was complianced in early 2002, and came to Australia with 52,000km (I have the original advertisement and pics of car at dealership). The first Australian owner only had the car for 3 months (lost his licence) before I purchased it from him in July 2002 with 58,000km. It has only travelled 31,000 in nearly 5 years of my ownership. Needless to say I don't do many kms each year.
It has been garaged every night since I bought it and rarely driven in the rain. I treat my cars with the utmost level of mechanical sympathy, and can guarantee that this car has never been thrashed in my hands. I have also had the car serviced every 5,000kms by the same brilliant mechanic who knows the history of the car.
The car comes with a wide array of OEM parts and also has the user manual in the glovebox. Water pump and timing belt have been replaced.
I have receipts for just about every cent that's ever been spent on this vehicle.
1992 Nissan Skyline R32 GTS-T
89,000km
Excellent condition - especially the shine of the paint
11 months registration
Black
Manual
Sunroof
  • Nismo bodykit (side skirts & GTR front bar) - Have additional 'spare' rear pods/spats too
  • Mick's Metalcraft 600x300x76mm front-mount intercooler
  • Turbosmart dual-stage boost controller w/rocket-launcher switch (currently set to 12/14psi) - Still have the box
  • 3-inch dump pipe and cat > 3.5-inch exhaust w/dual silencers > 5-inch tip
  • Power Enterprises pod filter (less than 5,000km old)
  • Excedy Heavy Duty clutch (less than 10,000km old)
  • King Springs all round (lowered 2 inches) - Still have original springs
  • Falken GRB451 225/50Z16 tyres (~10,000kms)
  • Autometer Phantom boost gauge - Still have the box
  • Greddy Turbo Timer
  • MOMO Race steering wheel
  • JVC KDS-785 CD/MP3 headunit (remote) w/Boston Accoustics speakers (deck comes with instruction manuals)
  • White side-indicator lenses
  • Custom number plates (subtle, but cool) - No yearly charge
Asking $12,000 neg.
Contact Oliver on 0401 057 830 or [email protected] - I am located in North-West Sydney.
NB: Some photos show car fitted with carbonfibre bonnet and GTR wing. C/f bonnet is gone but GTR wing is still available for purchase with the car (or separately).
Edited by HSVKLR
https://www.sau.com.au/forums/topic/168541-r32-gtst/
looks mint mate.........good luck with the sale....by the looks of it, well worth what your asking. :cool:
Thanks mate.
Sold it just a few hours ago for the asking price!!!
That's right, if you've got the best, people are willing to pay for it.
Damn, I'm going to miss my line... :thumbsup:
https://www.sau.com.au/forums/topic/168541-r32-gtst/#findComment-3155984
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
