  • Replies 92
I will one day fully restore/improve a 240z if I ever get my own house with a Garage.
Ohhh 240z, how I love thee.
Other cars I think are worth a mention are:
240z, 260z, 280zx, z32 300zx, 350z
M5
Countach, Diablo VT, Diablo VTT (oh baby)
Fazza F-40 F-50 Testarossa (sp.)
All Aston Martin's (Vantage, Vanquish, Zagato)
AC Cobra
Most Lotus's (Super 7 and all copies)
Aerial Atom
Caddy Cien
Corvette z06
I love Jags so most jags
RX-7 FC FD RX-8
Pagani Zonda!
Most Porches, and all modified Porches (gemballa etc (sp.))
Supra
All TVR's
If you didn't make this list you need to try harder.
Greg.
A VS,5 litre ute, dark blue,a set of 15' back mags, mack truck mud flaps the full length of the rear bumper, an ex truck bull bar with appropriate spotties, an array of quality stickers to cover my back window ( i would go with ones like Living Dolls, Bundi, Nothing Beats A Country Crowd, Jim Beam and 2001 Inseminators and a set of those rock guards down each side.
M5
AC Cobra
Aerial Atom
Caddy Cien
Corvette z06
RX-7 FC FD  RX-8
Pagani Zonda!
Supra
All TVR's
Greg.
Greg !! You're just too greedy !!!!
Cuongs Z will do. 240Z with an RB26 and a GT35 BB turbo and
every option you can dream up inc tower to tower roll cage.
The toughest car in WA no bull. Big HP, big brakes top suspension
Low KGs and the looks to die for,Little Prick won't let me have it.
Ric is ready to finish the story Cuong when you ring him.
Id love to have a nice shiny 340z, but a killer ironmask DR30 would be so very very nice.
They might be affordable, but theyre just too impractical in terms of maintaining and restoration.
If were talking weekend toys, this would be very nice. And affordable. The perfect car for perth in summer.
http://www.go-t-rex.com/tr/index.htm
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
