  • Replies 136
well here's the update.
removed bent bit of exhaust and replace with pipe for the meantime.
went to heasmans to check that car was straight and alingment was good. thankfully everything was fine.
washed car to try and remove the kilos of dust all over it.
heading to oran park tomorrow to get back on the horse.
and for those keeping up with the lingo.
blown engine = B-man'd, or D-man'd
drag explosion = Ben-man'd
circuit wall love = brisbied or possibly just "doing a fatz" who is renowned for being attracted to concrete. :sleep:
OZGTR and I are going to go out for a little play tomorrow. GTR jason is coming out too so it should be a ripper. john will be polishing his helmet though so we'll have to carry on without a zed.
richard does the spare fit in ok. the boot floor was a bit squashed. good to see you out there on the track not like the others who only like to bag you. there must have been oil on turn 10 becasuse it slippery.
well I got back on the horse today. out at oran park. A little tentative at first as the turn 10 EC excursion was my biggest off so far by a long way. I suddenly found myself noticing where all the walls are! got over it after about 3 laps. had some fun. got the exhaust fixed yesterday and took the car to heasmans to make sure it's all still straight and that the alingment was ok (which it was on both counts thankfully). next week will have it all fixed up as looking at it damaged is just a reminder.
Thanks for the encouragement greg and the excuse for me. haha :) I hadn't thought of oil, but it certainly was a savage loose. looking at the tape I think you could be right as I was a little bit off line and as I turned in car just snapped backwards. I had time to get about half a turn of opposite lock on, but it didn't do anything. After it happend I thought I must have just been slow to correct, but looking at the in car tape I was on the wheel pretty rapidly but just to no effect. I do remember a torana was putting oil down around 9/10/11 and 12. hey it works for me!
How is your car? Darron was saying just the lightest touch?
It was a good thing I was out at Oran today. Glen Seton was there testing a sports sedan and as some of you guys know the seat in my car is out of Glen Setons old FPR V8 Supercar. I told him about it, and he signed it for me! Nice guy.
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
