Hey guys,
Ive had my 4 door for a while now, i bought it stock, theres no badging on the exterior of the car at all. Im just curious about a badge on my passenger side dash, its says HKS SPORTS in silver, its not a sticker, its an actual badge of some sort, im just wondering if anyone else has something like that? or is it just wank factor from the previous owner?....i bought it from an import place so it was just complianced when i bought it. THe only thing missing on the car when i bought it was a strut brace, i can see that because its left two circles in the engine bay of where it must of been for a very long time. Oh and it had a set of 18's, but i swapped them for the standard rims.
Its just a really random badge, wondering if anyone would know anything about it, ive looked at heaps of other peoples 4 doors but noone has one..... its located just above the glove box.
Its just annoying at the moment because i dont actually have anything HKS on my car, but i dont want to pry it off my dash and ruin my dash if its been there for a while....
Oh and i was wondering also; under the 2 front seats there are what appears to be a vent underneath each and a harness with a plug on the end. I looked to see if i can find a connection anywhere that the plug is within reach but it doesnt seem to plug into anything. Was is just normal factory harness of electric seats or something? In case that option was chosen?
Any insight would be appreciated, thanks
:D
https://www.sau.com.au/forums/topic/168633-few-random-questions/
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
